Author Topic: Speedometer working, but not Odometer 1982R65  (Read 2040 times)
Re: Speedometer working, but not Odometer 1982R65
« Reply #15 on: June 01, 2012, 09:35:30 AM »
I've super-glued them back together successfully. Just be careful of creating a lump at the union.
Sava66
« Reply #16 on: June 01, 2012, 02:53:11 PM »
i just want to visualize what i'm getting into before I break down the speedometer.
« Reply #17 on: June 01, 2012, 03:43:27 PM »
This article is for an R100GS but does show the technique to remove the crimped-in-place bezel.
http://www.gunsmoke.com/motorcycling/r100gs/speedometer/index.html
Good luck. ::)  And check for a PM to you.
« Last Edit: June 01, 2012, 03:44:35 PM by montmil »
« Reply #18 on: June 01, 2012, 03:55:52 PM »
Could you post this link in the FAQ/Procedures section, it's got some great info and won't get too 'buried' in there, like it would here  .
« Last Edit: June 01, 2012, 03:57:05 PM by Bob_Roller »
« Reply #19 on: June 02, 2012, 08:03:31 AM »
I can do that. [smiley=thumbup.gif]
Sava66
« Reply #20 on: June 02, 2012, 11:21:38 AM »
wow fixing a speedometer costs minimum 150 euros here and a 3-4 week wait. Wirespokes, in your opinion, is this something a novice can do? If I take it apart, and get stuck, can I take pictures of the pieces and have you walk me through it? what is the trick to fixing it?  Is the trick just making the two gears stick? If I mess it up, can I just send it to you in pieces to fix? What is your turn around time?
« Reply #21 on: June 02, 2012, 11:39:28 AM »
That's a lot more than I charge! A LOT more. And I get concerned when it's not returned in a week!  ;D
Sometimes it's taken three or four weeks and I feel rotten about it.
That's a tough question whether a novice could do this or not. There are skills and tools needed for the job that not everyone has. I've been opening up things my whole life, and the first ones didn't always fare so well. But with each failure or mistake, I learned. So I guess it depends on your mechanical aptitude and patience. If you're a very patient kind of person and enjoys (or can handle) working on small things and making, what seems like, very little progress, then you probably can do it.
Sometimes the simplest things can take quite a while to do right. You'd think removing a bezel is simple as just opening the crimp. Well, yeah, unless you want to re-use it and have it look like it's never been off.  :)
There are instructions on the net in various places, and not difficult to find. And yes, the problem with the odometers tends to be a certain pot-metal gear that slips on the shaft. Guys have reported success in carefully JB Welding the gear to the shaft. Sometimes that hasn't worked, but may have been because the surfaces weren't totally clean of oil or not given enough 'tooth'. I do a fix that fixes the gear solidly in place and definitely prevents any unwanted movement.
Sure - you could send it to me! In pieces or whole. It doesn't sound like it needs any machine shop work (shafts, bushings, etc) so count on a week, maybe less.
