Author Topic: Synthetic Lube ?  (Read 3685 times)
thrang
Re: Synthetic Lube ?
« Reply #15 on: June 26, 2007, 06:03:49 AM »
I'm not a fan on synth oil.
Its expensive and given the service gap on a boxer not worth the cost.
As far as the engine goes I just run bog standard 10/40 oil on a 4 to 5k change interval.
I do my gear box  twice a year, mainly because I live in one of the wettist parts of the UK and the top seal on the speedo drive is not brilliant at keeping the rain out. Since mayoniased gearbox oil is not a nice sight, so its worth while keeping a close eye on the rubber and replace it if it starts to crack or turn brittle. I do the shaft oil and drive box once a year.
« Reply #16 on: June 26, 2007, 09:02:01 AM »
All I was trying to say is that dino oil aint that bad. And synthetic aint that good.  Certainly in this application, in the UK, where the cost of synthetic is twice the cost of a very good dino oil.
We all need an excuse to look at our old bikes more often....
horses for courses.
Who wants to argue about tyres?
Steve H
« Reply #17 on: June 28, 2007, 03:45:05 PM »
Spectro - I usually buy a case at a time.  Last time it was about $70 for a case of twelve.
TTFN,
« Reply #18 on: June 29, 2007, 07:03:28 AM »
As far as dino oils, I have used Castrol GTX since the mid 70s.  Back in the day I noticed considerably less varnish buildup on the inside of engine cases (jap bikes) when tearing down engines that had used Castrol.  Quaker State engines seemed to be the worst...
airhead
« Reply #19 on: June 30, 2007, 04:04:05 AM »
Castrol oils, particularly GTX, were always noted as being very high detergent oils. A common warning was not to switch to it after using low detergent oils as it would clean up the system too well and either load the filter system, or drag sump contaminants through all the bearings.
I used it exclusively on my VW's and noted just how pristine the case and sump areas were compared to other engines not using it. Some preferred not to use it, particularly if a filter wasn't used, as the theory was that contaminants were carried within the oil (albeit captured and coated) if not captured by a filter and not settled out at rest. Can't comment on that, but it always gave me great service and I only stopped using it in later years when GTXII came out with a lower viscosity 10W50, and my car (Toyota Corolla) started using oil. I now use Valvolene XLD 20W50 in the car.
Bill....................;-)
