The alternator is located under the front cover.
The cover is held on by two allen head type fasteners .
There a 'hot' connections under the cover, by that I mean they always have battery power available to them, regardless if the key is in the ignition or not .
Remove one of the battery cables and secure it out of the way .
The cables are old and have taken a shape over the years, that will allow them to move back if they aren't secured by a ty rap or something similar .
The alternator is easily replaced, you can replace the rotor, stator, diode board rectifier, or regulator itself, not a 'package' like on a car or truck .
