Author Topic: R65 intake rubbers  (Read 810 times)
oz_johnno
R65 intake rubbers
« on: March 14, 2012, 06:40:21 AM »
blokes, I pulled the carb intake rubbers off today.  I had to  do this very carefully as they were cracked and very hard.
For a set of these rubbers munich motorcycles wants $66 + $9.50 p&h for what looks like 4x 1.5" lengths of radiator hose.... talk about rip off.
does anyone know the diameter of these hoses so that I can investigate alternatives ??
OZ
Re: R65 intake rubbers
« Reply #1 on: March 14, 2012, 07:10:52 AM »
I've also noticed that they seem expensive and share your concerns but I don't think you can safely assume radiator hose will work well as substitute. It will depend if the rubber is fuel resistant and I doubt that. Probably needs to be Nitrile rubber.
How about large diameter fuel hose if it can be got in the correct size ?  I found something close at 38mm. See the 1 1/2 " hose in this link
http://www.hoseshop.net/discharge-and-suction-hose/oil-resistant-discharge-suction-hose.htm
Having removed them you are probably in a better position than us to measure an accurate figure off the the carb stubs.
Hope you find something that works.
« Last Edit: March 14, 2012, 07:27:26 AM by bhodgson »
« Reply #2 on: March 14, 2012, 09:47:21 AM »
Check this link with photos at Motobins. 6.25£ each is better than your quote.
I also bought new hose connectors sometime ago for one of the R65s from Hucky's in Florida. Non-BMW repops; probably auto parts hose. Fabric reinforced rubber with a smooth interior. Maybe source something local. Way back, I bought the correct size hose at a NAPA auto parts store for the intake manifold rubbers on a VW aircraft conversion. I ran auto fuel. Never a problem.
