Author Topic: Clutch Removal Question  (Read 5245 times)
Re: Clutch Removal Question
« Reply #15 on: January 03, 2012, 07:37:58 PM »
Maybe I don't push these bikes that hard, but I have had the slipping clutch phenomon - so guess I've been lucky. I've never replaced a clutch (of my own) that had some oil on it. I cleaned them off best I could till they had that new sort of look, sanded perhaps, and used em. Brake shoes, same thing.
Here's what I figure: old grease gets really sticky! Ever notice! So if you get as much off as you can, then take it easy at first (you should take it easy on a NEW clutch anyway), the heat will boil off the rest and make it real  sticky! :-)
PB blaster is real thin and should clean off pretty easily. I wouldn't worry about it. Use any good solvent - and maybe finish off with brake cleaner.
All this is assuming it's still within servicable limits?
zebedee
« Reply #16 on: January 05, 2012, 09:50:23 AM »
I guess I will have to swallow the bitter pill of the cost of a new clutch, but I agree that it is better to make sure. I know the feeling of trying to accelerate and having only the engine getting with the program. :-? thanks,D2
When my clutch started slipping a little at about 100,000km I had the drive plate relined for about $100. Because the clutch hadn't been allowed to get too hot, the spring and pressure plate were fine, and with new thicker friction material it was like new.
Any decent brake place (as opposed to franchised parts installer) should be able to reline the driven plate. They will want to know how thick it should be.
« Reply #17 on: January 05, 2012, 10:05:48 AM »
A tip, on having the clutch disc friction lining replaced .
About 5 years ago, I took the two plates to be machined and have the clutch relined, to make a long story short, the machining workmanship was horrible .
After installing the reworked parts, I couldn't get the proper adjustment at the adjustment bolt at the back of the transmission .
Needed a bolt about 6-8 mm longer, that cured the problem, seems like the thicker the friction lining the longer the bolt you need .
Offline Dave 2
« Reply #18 on: January 07, 2012, 07:55:52 AM »
Taking everyone's thoughts into consideration I decided to go over the clutch surface with 220 wet/dry sand paper to clean it up and then I gave it a good scrubbing with brake cleaner [smiley=mad.gif] (I moved that operation outside!) Then I showed the clutch to the foreign car mechanic in town and he said it looked as good as new, with barely discernible wear [smiley=bmw_smiley.gif] So I should be good to go with that. D2
« Reply #19 on: January 07, 2012, 08:13:48 AM »
How much friction lining do you have past the rivet heads,?
That's pretty much the determiming factor on clutch wear .
Offline Dave 2
« Reply #20 on: January 07, 2012, 01:35:29 PM »
Bob, I have an overall thickness of .230 inches or 5.842 MM. Clymer calls for 4.5 mm so I should be good with that measurement. I used a 6" Dial Caliper to measure so I'm not positive of my measurement from the top of the rivets to the surface of the disc but it was approx. 35 mm. I do not have a table for that measurement, does this sound OK to you? D2
« Reply #21 on: January 07, 2012, 01:43:59 PM »
I really don't know, when I replaced my clutch disc, I forgot to measure what the distance was from the rivet head to the lining surface .
If you are well within what the manual calls out for, I don't think I'd get concerned about it .
« Reply #22 on: January 07, 2012, 10:06:54 PM »
New is 6mm,  worn out = 4.5mm. Yours is very close to new.
They wear more on the edge than towards the center. Did you measure on the outer edge?
Offline Dave 2
« Reply #23 on: January 08, 2012, 06:36:20 PM »
Yes Sir, I measured around the outer circumference. D2
« Reply #24 on: January 08, 2012, 07:05:37 PM »
That's excellent! You've got yourself a good one.
« Reply #25 on: January 08, 2012, 09:03:46 PM »
FWIW - most dial calipers I've seen also have a depth measurement (which slides out from the bottom of the  'handle/ruler as you adjust the wheel).   You would use this to put against the surface of the friction material and measure the depth of the rivet head in the hole.
In any case, it does sound like yours is only slightly worn as they are right around 6mm thick out of the box.
Offline Dave 2
« Reply #26 on: January 09, 2012, 04:49:20 AM »
Yes, I used that slide out rule, but my eyes are not what they used to be  :o so that measurement of .35 is a little iffy. D2
Offline Adrian
  • The Old Hairy Biker Sez...
« Reply #27 on: January 09, 2012, 05:33:41 AM »
Hi Dave - back online at last. I'm trying to catch up with your posts as we are doing the same work. I'm not going so fast but I'm managing an hour most days. Thanks to you the mystery of clutch and wheel bearing removal has been simplified. I shall save a fair few dollars now as I have the confidence to tackle these jobs myself. You mentioned in one of your posts about having the wheels powder coated. Did you get a result as yet? I'd be interested in what you think about the results. Thanks mate hope yer well. Adrian
1984 R65 (860)
Offline Dave 2
« Reply #28 on: January 09, 2012, 11:03:55 AM »
Hey Adrian good to hear from you again. I appreciate your comments but I just asked the questions and all the good folks who answered them deserve our thanks. I think it is so cool to get the confidence shared by others to tackle the restoration process. The mystery of things like a stuck clutch goes away real fast when you can actually take it apart and see for yourself how it works [smiley=bmw_smiley.gif] I'm still waiting for a tool part to arrive in the mail so I can remove the swing arm bearings. The foreign car mechanic up the street said I could bring the swing arm up and he will use his press to separate the driveshaft. Then I will get the frame and wheels taken care of. The way things go I figure in two weeks I'll have some pictures to post. Happy New Year mate. D2
