Author Topic: Instrument panel overhaul on '81 R65  (Read 2359 times)
Offline Dave 2
Re: Instrument panel overhaul on '81 R65
« Reply #15 on: November 30, 2011, 08:09:53 AM »
Hi Luke, you have already received some great replies, but I have posted two photos of the front my 1983 R65LS showing the "Headlight Panel" which must add some rigidity to the forks and serves as a support/mounting piece for headlight, instruments, Front brake lines, clutch cable,turn signals, and a major route for the wire harness serving the front electrics including your charging and ignition system. In the picture with the headlight you can sort of see the remaining piece of my dash panel that remained on the instruments. My dash had the turn signal indicator lights set into it. I hope this helps for you to see a stock set up. Good Luck, Dave2
« Reply #16 on: November 30, 2011, 10:56:13 AM »
Luke,
TRy this link, this set of photo's and the amazing detail of the job inspired me to rebuild my bike.
I use this a lot for reference, it is superb...
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/
