Author Topic: Beancan sensor. Thank you..!  (Read 909 times)
paulh
« on: September 24, 2011, 05:59:21 AM »
Guys.. just a quick thankyou to those who advised me regarding the problem with my R65 beancan sensor.
The sensor arived, i stripped the beancan and fitted the sensor following the great instructions i found on-line and was told about from here, and now my little R65 is running so sweet.!!
Many thanks... Paul
Re: Beancan sensor. Thank you..!
« Reply #1 on: September 24, 2011, 08:05:26 AM »
Any tips about doing the job, things to  avoid etc.......
« Reply #2 on: September 25, 2011, 07:45:48 AM »
Couple links here, Bob, that worked for me.
Can be a bit fiddly, but you've likely already got the skills with your career experience. Some 22ga wire soldering required and do be careful removing the solid rivets holding the sensor to its base plate. Same care required when refitting the new sensor. Tight working area doesn't begin to describe the work space. ;D
Several shims, washers and fiber spacers inside the can. They will often stick together during disassembly, then separate when you toss the "single washer" onto the bench. Jeez, wonder what order they were in?
I've rebuilt four bean cans, mine plus the three I've bought around the www. One was truly butchered by the PO so took mucho love to rebuild. A spare is handy to have on longer rides. Naturally, after fixing my own can, I've never had another problem. Go finger... uh, figure.
http://robfrankham.co.uk/bike/replacing_the_hall_effect_sensor.htm
http://maniac.deathstar.org/%7Eflash/ig_trig.html
« Last Edit: September 25, 2011, 07:46:24 AM by montmil »
