Author Topic: R65LS front disks.  (Read 879 times)
Offline beemer
  • The Red Tomato!!!
R65LS front disks.
« on: August 13, 2011, 11:04:46 AM »
Hi all,i want to replace the 2 front brake disks on my R65LS will 2 from a standard R65 fit?thanks.
Re: R65LS front disks.
« Reply #1 on: August 13, 2011, 07:30:11 PM »
I think that the rotors will work, but I'm not sure if the carriers are the same (hub thickness) or not.
« Reply #2 on: August 13, 2011, 08:41:49 PM »
The standard BMW discs don't separate into carrier and disc. The non-LS disc is deeper by maybe an inch, so wouldn't work on an LS.
« Reply #3 on: August 14, 2011, 04:21:55 PM »
It wouldn't be hard to drill out the rivets and replace them, with short bolts if necessary - with many of the aftermarket rotors that fit the R65 application, that is what one does anyhow to re-use the carrier, assuming it is in good condition.
