Author Topic: Threaded stud  (Read 822 times)
stockman
Threaded stud
« on: April 27, 2011, 10:05:40 PM »
On the left side of the motorcycle where the clamp going around the exhaust pipe is attached to a stud1/2" in dia roughly. Is that stud removable? Could I get a longer one? I'm adding a side stand I picked up locally from a BMW repair shop and really would like to have that stud 1/2" longer to accommodate the the bracket that the clevis for the stand is mounted to. It's not entirely necessary, I could maybe find a hex nut that is shorter or use a nyloc nut. Anyone know?
Offline wilcom
Re: Threaded stud
« Reply #1 on: April 27, 2011, 10:16:48 PM »
I think your talking about the thru bolt that mounts the engine, It has a nut on both ends, loosen the right side and tap it farther to the left so you'll have more bolt to work with.
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
stockman
Re: Threaded stud
« Reply #2 on: April 28, 2011, 06:27:50 AM »
Ok great that's perfect. Never would have thought it's that simple. Thanks
stockman
Re: Threaded stud
« Reply #3 on: April 30, 2011, 11:14:31 AM »
What would be the appropriate torque for the engine mounting bolts?
Just to make sure I don't have them too tight or loose.
Re: Threaded stud
« Reply #4 on: April 30, 2011, 01:56:52 PM »
Your shop manual will have all the torque specs you'll need.
stockman
Re: Threaded stud
« Reply #5 on: April 30, 2011, 07:40:41 PM »
Yes I know.
