Author Topic: Hesitant after diaphram change!!  (Read 2633 times)
Offline beemer
  • The Red Tomato!!!
« on: April 11, 2011, 07:06:30 PM »
I recently changed my carb diaphrams on my R65LS 83 model and now she just won't go past 60mph!!!feels almost like fuel starvation,plenty of fuel flow,checked valves clearance,plugs,ignition coil seems fine,i have a spare coil so changed over just incase,bike starts and idles fine,help and advice please,thanks.
Offline wilcom
Re: Hesitant after diaphram change!!
« Reply #1 on: April 11, 2011, 09:12:48 PM »
Take your finger and lift each slide and feel the suction/vacuum.  Do they feel the same? May have a leak on one of them. I had one tear on a trip and she wouldn't run at all, idled like a champ but wouldn't take any throttle at all.
Good luck
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: April 11, 2011, 09:55:58 PM »
By chance did you purchase 'pattern' parts from Motobins ?
A few of the UK members on this forum installed them and the thickness of the diaphragm caused problems, can't quite remember what they were .
I'm sure they'll post a response tomorrow .
« Last Edit: April 11, 2011, 10:08:42 PM by Bob_Roller »
« Reply #3 on: April 11, 2011, 10:36:16 PM »
Yes, there are "non-Bing" replacement diaphragms that are the same overall shape but the rubber is definitely thicker and stiffer - these have caused issues with a number of folks.  Also, be sure that you have them properly oriented/seated with the small tab going into the indented are on the inside edge.
Offline beemer
  • The Red Tomato!!!
« Reply #4 on: April 12, 2011, 04:37:44 AM »
Yes these are the "non bing"type,can anything be done?or do i have to replace them?thanks. :(
« Reply #5 on: April 12, 2011, 05:19:07 AM »
Perhaps ask Motobins for a full or partial credit with an exchange for the "real" Bing diaphragms. The thicker rubbers will likely be problematic for, oh, forever. Sometimes pattern parts work just fine.
« Reply #6 on: April 12, 2011, 12:35:01 PM »
I was one of the folk with trouble with these only fit Bing originals the generic ones are cr*p especially troublesome if you have the flat top carbs. Also check the rubber connector to the heads have been properly refitted.
« Last Edit: April 12, 2011, 12:37:31 PM by Lucky_Lou »
« Reply #7 on: April 12, 2011, 01:13:39 PM »
On the one hand you have to wonder why Motobins and others continue to sell the generic diaphragms if they are so bad.
On the other hand you have to wonder why the thicker rubber makes so much difference when the old Stromberg and SU type CV carbs used to deliberately add damping with an oil dashpot.
Thankfully I've not had to replace mine yet.
« Reply #8 on: April 12, 2011, 03:21:16 PM »
The Bing CV carbs works on substantially lower vacuum (pressure? or rather suction) than other CV designs from Mikuni, Keihin, etc.  The thicker rubber is certainly stiffer/ less pliable as has been demonstrated with testing deflection while applying specific weights.  The relative differences in overall carb vacuum is especially apparent when I am working on my Japanese motorbikes and my BMW airheads with my Morgan Carbtune (rotameter).  One has to stand the carbtune upside down and let gravity assist the steel slides' movement when working with the bings - this makes the rotameter's full scale reading approximately 20 mm/HG, whereas in its normal position full scale is closer to 200 mm/HG units, which is what I use with the Kawasaki's carbs.
Just get the bona-fide Bing rubbers and you'll be happier!
« Reply #9 on: April 12, 2011, 04:06:50 PM »
Dome-tops also may or may not have a return-assist spring (#7).
If you have these in your carbs, try removing them and see what effect that has.
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=13_0462&hg=13&fg=05
I saw a pair of R100 dome-tops just this last weekend taken apart, and there were no springs in them.
The bike ran fine.  (Bing diaphragms)
« Last Edit: April 12, 2011, 04:08:19 PM by Rob_Valdez_79_R65 »
« Reply #10 on: April 12, 2011, 06:48:20 PM »
An old saying from P.T. Barnum, of circus promotion fame; "There's a sucker born every minute."
Prior to rebuilding the Bings on my 1981 R65, I did a lot –and I mean A LOT– of internet research on how to do it and how not to do it. The knock-off Bing diaphragms were noted as to be avoided like the plague.
Offline beemer
  • The Red Tomato!!!
« Reply #11 on: April 12, 2011, 07:54:16 PM »
Well according to them these are fine and they haven't had any problems with them!!so you have to take their word for it i guess,why doesn't it show up being hesitant when you just rev the bike?i guess it has to be under load,ie,when your on the move.
Offline beemer
  • The Red Tomato!!!
« Reply #12 on: April 12, 2011, 07:56:54 PM »
Thanks,i will try this.
Offline beemer
  • The Red Tomato!!!
« Reply #13 on: April 12, 2011, 08:32:25 PM »
which rubber connector Lou?
« Reply #14 on: April 12, 2011, 09:55:27 PM »
#3
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=13_0455&hg=13&fg=05
That HAS to be an air-tight seal.  It can be checked by spraying carb cleaner on them while the engine is running.  If the RPM's rise, you know you have a leak.
The rubber gets hard over time and can even crack.  Best to replace them every 10 years or so.
