Author Topic: Quick Brake Disk Question  (Read 1425 times)
Offline Julio A.
« on: April 07, 2011, 10:32:17 PM »
Does the Earlier dual shock R65's have the same Disk up front with the newer Monoshock R65's?
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Quick Brake Disk Question
« Reply #1 on: April 07, 2011, 10:56:33 PM »
No, they are not interchangeable .
Offline Julio A.
« Reply #2 on: April 08, 2011, 06:40:16 AM »
Ok, but do you think it is possible to fit a monoshock disk to the older dual shock models with modifications?
Besides offset,do you know any difference between the diameters of the two rotors? Do you think it is possible to fabricate a spacer of some sort so I could correct the offset between the two two rotors?
I desperately need a new rotor but the only one readily available is from a monoshock R65 from the spare parts. I couldn't compare the dimensions since the bike is parked somewhere else.
« Last Edit: April 09, 2011, 01:18:02 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
zebedee
« Reply #3 on: April 14, 2011, 02:01:12 AM »
The only thing the R65 Mono brake disk has in common with the R65 twin shock brake disk is that its off a bike called an R65.
(oh, and its circular)
« Last Edit: April 14, 2011, 02:01:43 AM by zebedee »
