Author Topic: oil pressure sending unit  (Read 2396 times)
wxp
« on: March 13, 2011, 08:43:24 AM »
Any one have a list of part numbers for parts they used other than OEM BMW parts.
Like a napa part number for the oil pressure switch?? :-/
Re: oil pressure sending unit
« Reply #1 on: March 13, 2011, 08:56:01 AM »
Wells Mfg. Corp. PS 102 Oil Pressure Switch is exact replacement for BMW switch and can be purchased from most auto parts stores as Volkswagon Beetle Oil Pressure Switch....
http://www.ibmwr.org/otech/partsubs.shtml
« Reply #2 on: March 13, 2011, 10:32:06 AM »
May be a good idea to take your old OP switch with you and compare threads. Some similar-looking sender switches for germanic vehicles have different threads. Safer than an oops and bodged engine case threads.
« Reply #3 on: March 13, 2011, 02:15:39 PM »
There is an oil pressure sender in the attached Word document which is a list of subsitute parts shamelessly copied from this web site http://www.ibmwr.org/otech/partsubs.shtml.
I just filtered out the parts not relevant to our bikes.
« Last Edit: March 13, 2011, 02:20:51 PM by bhodgson »
wxp
« Reply #4 on: March 13, 2011, 03:57:18 PM »
Thanks
Offline R65Guy
  • I'd rather be ridin'
« Reply #5 on: March 14, 2011, 01:17:51 PM »
Airhead guru Snowbum discusses oil sender switches on his website:
http://bmwmotorcycletech.info/Oil.htm
Skip to notes 21, 22 & 23...
His basic concern (although minor) is the BMW switch activates <8 psi and many aftermarket switches activate in the 25 psi (or more) range. Extremely hot oil and/or heavy braking could cause the aftermarket oil switch to activate under normal operating conditions - thus causing needless concern.  According to him ~15 psi would not be considered abnormal in certain conditions.  Food for thought.... ymmv
81 R65 & 16 R1200GS
« Reply #6 on: March 14, 2011, 01:59:07 PM »
Snowbum also points out that the OEM switch is only around $10 ($10.65 at Hucky's).
For that price, I can see NO reason NOT to use OEM.
« Reply #7 on: March 15, 2011, 02:57:53 PM »
I have bought one Borg Warner OP switch (for mid 80s BMW car) and it was almost $2 more than  the Chicago BMW price for stock unit...
wxp
« Reply #8 on: March 20, 2011, 04:34:45 PM »
one just assumes parts from bmw are going to be more expensive..even w/shipping usually just as much
« Reply #9 on: March 20, 2011, 07:07:43 PM »
It would have been more from the local dealer but cheaper from Chi. BMW.  The up-side was that I had it immediately...
« Last Edit: March 20, 2011, 07:08:28 PM by admin »
