Author Topic: LS instrument cover refinishing  (Read 1509 times)
lfdelrio
« on: January 31, 2011, 10:40:02 PM »
Hi all,
I've been thinking of refinishing/painting the instrument cover/dashboard on my ls as it has a couple of deep scratches. Has anyone attempted to do this? If so what did you use to fill the scratches? ABS cement?, glazing putty? . Any suggestions on the color> I was thinking satin black or semi-gloss black.
Thanks in advance
Luis
« Last Edit: February 01, 2011, 05:55:58 PM by lfdelrio »
bruce_launceston
Re: ls instrument cover refinishing
« Reply #1 on: February 01, 2011, 02:10:28 AM »
I have repainted my LS cover with a good quality matt black spray can. I filled some small stone chips on the smooth section with body filler first.
« Reply #2 on: February 01, 2011, 03:31:02 AM »
I'm not sure how you could duplicate the texture.  Hopefully someone has done it with success, before.
Rat bikes rule! ;)
« Reply #3 on: February 01, 2011, 07:04:22 AM »
Rat bikes rule! ;)
Rob I think they are talking about the smooth cover that goes on top of the small fairing, not the textured rubber that goes around the indicators .
« Reply #4 on: February 01, 2011, 04:38:29 PM »
Ah - it must have been "instrument cover/dashboard" that threw me.  I missed that he has an "ls" (LS).
I don't need to identify my bike in my sig line, it is in my name.  Well, parts of it, anyway! (I'm on my 3rd engine and second transmission...  :P )
« Last Edit: February 01, 2011, 06:05:38 PM by Rob_Valdez_79_R65 »
lfdelrio
« Reply #5 on: February 01, 2011, 05:55:39 PM »
Thanks for the replies, yes I did mean the smooth part on my LS (my bad).
Bruce, did you use a primer or adhesion promoter at all? (on the filler or the rest of the instrument cover) Or would pastic-specific paint be enough?. Also did you paint the textured part or just masked it. Although I have some experience painting metal, and fiberglass parts I've never painted plastic so I thought I'd ask before I make a mess.
Luis
Offline Julio A.
Re: LS instrument cover refinishing
« Reply #6 on: February 01, 2011, 06:15:22 PM »
I've painted on an actual LS before, but I have painted numerous damaged plastic parts.
I never used primer before, but the filler I use was a mixture of epoxy and "microballons", a light and dust like additive to make it softer and easier to sand down.
Sometimes I just scuff the plastic with some fine grit sandpaper if there are only light scratches before painting.
« Last Edit: February 01, 2011, 06:16:44 PM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
bruce_launceston
« Reply #7 on: February 02, 2011, 02:34:13 AM »
I just gave a light sand to the smooth section and yes I did paint the textured area as well this time.
Previously I masked this part off and only painted the smooth front part.
I didn't use a primer or plasticiser. I use K&H Matt Black in a spray can. It's also great for the lever mounts, choke lever etc. It has just the right semi-gloss level.
