They are numbered from the top, the uppermost groove is number one .
What is the series of numbers that are stamped on the vertical flange at the front of the carb .
Should be something like : 64/32/325
There were several different carbs installed on the R65 at the factory, most carbs have the needle in position three, but there's two that have different needle positions .
