Author Topic: Upper throttle cable free play (at splitter) 82LS  (Read 708 times)
lfdelrio
« on: November 13, 2010, 10:33:10 PM »
Hi all,
I've been working on slowly restoring my 82 LS and just replaced my throttle cables. Now I know I'll need to set the free play at the carbs to 0.5-1mm followed by synchronizing the carbs. My question is about the free play at the splitter (upper cable) I've looked at the owners, Haynes, and clymer manuals and none mention what it should be. I was hoping you guys could help me out with this.
Cheers,
Luis
Re: Upper throttle cable free play (at splitter) 82LS
« Reply #1 on: November 14, 2010, 12:32:40 AM »
If you are measuring the free play at the carbs, the pressure you are using to pull on the outer cables should take up all of the slack in the splitter as well.  ...I think.
« Reply #2 on: November 14, 2010, 07:44:33 AM »
I like to have just a t-i-n-y bit of free play at the cable/twist grip junction after all the carb, splitter and cable synchro chores are completed.
« Reply #3 on: November 14, 2010, 10:16:44 AM »
You want the same amount of free play at the cable adjuster at the front of the cable splitter, the same as you would at the adjusters at the carbs .
lfdelrio
« Reply #4 on: November 14, 2010, 08:16:10 PM »
Thanks for the replies everyone I've now set the free play on all my the cables and will sync the carbs in the spring once I start riding the bike
