I finally got to remove the transmission from my '82 LS for an input spline lube .
I wasn't looking forward to this, as I've found a lot of less than desirable work performed on this bike .
1 hour 45 minutes from when I opened the tool box, until the transmission was sitting on the work bench .
Good news is, both the splines on the shaft and the clutch splines are in great shape and were properly lubed .
The input shaft seal is still good and I don't see any seepage from the rear main seal and oil pump cover seal, so I'm not even going in there at this point in time .
Clutch disc still has 15-20,000 miles of wear left on it, the bike will probably get a few thousand miles a year, so the next spline lube will require a clutch replacement .
About the only thing I have found wrong so far, that the threaded stud at the upper left hand corner, came out of the engine with the nut, most likely cause is the spacer that sits between the air-box and transmission mounting 'ear' was missing .
So far that looks like that might be the only part I have to order, if that's the worst I find, I'll be quite relieved .
But now I have to clean up everything I took apart .
Something out of ordinary happened when I pulled the rear axle out, the flanged or 'hat' spacer on the left hand side, pulled through the seal, the spacer was seized on the axle .
Looks like I need to use some fine emery paper on the axle and the inside of the spacer to get some clearance .
