Author Topic: '81 R65 electric diagrams  (Read 4530 times)
R65Biker
Re: '81 R65 electric diagrams
« Reply #15 on: August 30, 2010, 11:26:39 PM »
Hi there - saw your replies about the posibility of fuses being the cause of my problem. So quick to check and ... you were spot on.
Not blown - just a bad connection. Dash lights and lail lights all working fine again.
Thanks guys.
Will keep you posted on the cause of the low beam not working all the time...
R65Biker
« Reply #16 on: August 31, 2010, 02:46:17 PM »
Baught proper 8Amp fuses today and fitted them as suggested. I attached one spare fuse inside this black lid - just in case...
The good news - I started looking for the intermittent problem on the low beam. Saw that the cable was running under the tank so I removed it. Shook the cable only to find the red plug not securely pluged into it's female connector. Pushed this in and added a cable tie to the cable to prevent it from coming loose in the future.
I also flushed the speedo cable as suggested but it was too cold/late to take it for a spin to see if the jumping needle is also fixed now.
Thanks for all the good advice.
« Reply #17 on: August 31, 2010, 04:58:22 PM »
Well, it looks like you got a few low cost quick fixes, and learned a little bit about the bike in the process .
