Author Topic: Stebel Nautilus on 83 R65?  (Read 2839 times)
Re: Stebel Nautilus on 83 R65?
« Reply #15 on: June 09, 2010, 10:27:29 PM »
I've also done a full write up in the wiki with pics on installing dual FIAM horns using an off the shelf horn wiring harness from a company called Eastern Beaver.
« Reply #16 on: June 10, 2010, 09:17:42 PM »
I think if the bike originally came with dual horns it will have a relay, the single "disc" horn was ran right off the switch - at least on our '84...
« Reply #17 on: June 10, 2010, 09:50:58 PM »
Professional-grade electrical wiring, like coffee, begins with good grounds.
Oh that is good!  May I use that?  I've seen your electrical work and it is "professional grade" although for a man who gets his coffee fix from funeral homes I'm a bit surprised. ;D
I'd like to see that schematic for the FIAMM horns also.  Perhaps on the Wiki or maintenance links?  Had a pair on my K100RT and they were Mack truck righteous.  Always startled the heck out of me whenever the bars would flop to the left and the horn button would push against the tank bag.
