Author Topic: Choke Lever Operation  (Read 1136 times)
Offline Mike V
  • 78 R100/7 , 81 R65
« on: May 03, 2010, 02:50:43 PM »
All,
Wanted to run something by everyone to get some information. During my choke cable assembly process yesterday I noticed something I felt was a bit strange.  Still in the learning process for this bike...I noticed once the cables were hooked up and adjusted, while applying the choke thumb lever at the handlebar location I noticed the lever would not stay at the "full choke" location and wanted to creep back to approximately the 1/2 choke position with no "notch" or "detent" position. Is this correct? (81 R65). I disassembled the lever mechanism and noticed a small ball bearing pressed into the bottom side of the thumb lever that seems to ride along a recessed gutter section in the housing. Is the lever supposed to have a detent or ratchet notch restriction in it to stay in the full or 1/2 choke position?
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
Re: Choke Lever Operation
« Reply #1 on: May 03, 2010, 03:14:34 PM »
The 'choke' lever, at least on my '81, won't stay at full choke it springs back a bit , you need to hold it there.
There should be a noticeable half choke detent .
Offline Mike V
« Reply #2 on: May 03, 2010, 03:19:31 PM »
Thanks Bob, I must have a worn housing since I don't notice any detent even at 1/2 choke, although the lever seems to drift back and hold it's position at the 1/2 point. I'm guessing there should be a small port or notch for the ball to fall into which I can't notice in my housing after a close inspection yesterday. I'm thinking I can live with this.  Thanks again for the reply.
Mike V. / San Diego
« Reply #3 on: May 03, 2010, 05:51:24 PM »
My '81 R65 plays nice with the choke lever. The '83 R65, well, you gotta hold the lever in the full choke position. Both run so well that I ain't gonna mess with it.
Offline Mike V
« Reply #4 on: May 06, 2010, 01:26:43 PM »
Solved this choke lever detent problem (dummy). I often wondered what this little curved metal piece with 3 holes was lying on the floor months ago. Had this strange suspision it was important and couldn't get myself to throw it in the garbage.  Glad I didn't.
#6 on the attached link.
 http://www.realoem.com/bmw/showparts.do?model=0364&mospid=47851&btnr=32_0739&hg=32&fg=10
Mike V. / San Diego
« Reply #5 on: May 06, 2010, 01:39:27 PM »
Yup, that could do it!
My 82 will tend to stay on full choke (but not always) if I really pull it over, but mostly it eventually creeps back to half position and snaps/stays there until I close it.   My 88 R100RT behaved the exact same way.
« Reply #6 on: May 06, 2010, 01:57:01 PM »
You guys with the handlebar mounted choke have got it easy being able to pull in the clutch and operate the choke lever with the same hand.
I could use a 3rd hand to operate the choke lever on the air filter housing. It does stay put though.
