Author Topic: carb springs  (Read 592 times)
manxr65
carb springs
« on: May 02, 2010, 02:47:06 AM »
can i fit springs to my carbs, they are 64/32/353 to help with the idle as it is still revving a little high when im slowing down , this may help a little .
also can i remove the carb cv slide , it moves freely but would this make any difference . ie make revs come down quicker
r65 1979
Offline R65Singh
Re: carb springs
« Reply #1 on: May 02, 2010, 03:02:25 AM »
I think the problem might be with your BeanCan. It has advance mechanism in it and the weights might be sticking.  Try spraying some WD40 in there and that might help.  There are lots of threads in here on the same problem.  Hope this helps.
« Last Edit: May 02, 2010, 03:03:59 AM by koolzee »
1982 R65LS
1970 r50/5
1962 r50/2
1976 Honda Z50
Re: carb springs
« Reply #2 on: May 02, 2010, 08:06:33 AM »
A light oil or grease may be better than WD-40 as the "do all" spray will soon evaporate.
Re: carb springs
« Reply #3 on: May 02, 2010, 08:20:49 AM »
WD40 has a tendency to turn into a sticky varnish like material after the lighter components evaporate, I would try another lubricant .
I don't know if you have LPS products available in the UK or not, LPS 1, LPS 2, LPS 3, are good general purpose aerosol lubricants .
