Author Topic: My first attempt at carb balancing  (Read 2453 times)
plc
Re: My first attempt at carb balancing
« Reply #15 on: March 11, 2010, 02:09:41 PM »
Hi all,
I don't think air injection was fitted to any bikes that came to Australia.
Thanks to all for any advice given on setting up my bike to idle correctly. I think I have it pretty good now. With the mixture screws out almost 3/4 from seated to get a mixture that doesn't cause popping on the overrun and doesn't stall on sharp slow down. So thanks guys.
Mind you it is easy to become totally obsessed with getting the balance correct.
The Carbtune worked well but I didn't like the flutter in the tubes when setting the idle, fine for higher rpm but at idle the flutter was quite annoying.
Best to all,
Paul
noquarter
« Reply #16 on: March 26, 2010, 11:18:45 PM »
1 whole turn = 180 degrees?
bruce_launceston
« Reply #17 on: March 27, 2010, 02:02:35 AM »
 180 degrees is half a turn. ie flat side of screwdriver that was facing you is now at the back.
« Last Edit: March 27, 2010, 02:03:14 AM by bruce_launceston »
