Author Topic: To tube, or not to tube?  (Read 3426 times)
Re: To tube, or not to tube?
« Reply #15 on: February 25, 2010, 11:45:26 AM »
The snowflake rim does require a tube, regardless if you are having a tubeless tire installed, the cross section of the rim is different from a tubeless rim .
caci
« Reply #16 on: February 25, 2010, 01:07:14 PM »
Not wish to extend the debate too much but I thought it would be useful to compare the tubeless rim from Robs link with a picture of a Snowflake rim I took last summer. Remember Summer and flowers ? I always work in the garden rather than the garage when the suns out. The lack of any significant hump and different slope to the rim are obvious. What I want to know is if the snowflake rim is so unsafe without a tube how come it can be so damn hard to seat the bead and too break it again when changing tires ?
Barry,
Thanks for the illustrations of the conventional Tubeless Rims vs. LS (?) Rims.
SW Moto Tire mounted Bob_Roller's Lasertecs without tubes.  Bob, what are you trying to say with your last post?
Wow, talk about confusing.
I wonder just how different these tires would react to a "sudden deflation" with or without tubes?
Also, why would the "tubed" tire be any less suseptable to coming off the rim in the event of a punture severe enough to result in a "blowout"?
« Last Edit: February 25, 2010, 02:09:16 PM by caci »
« Reply #17 on: February 25, 2010, 02:49:17 PM »
Tubeless vs Snowflake rims. LS rims are different again. Although I've never seen one first hand I believe the profile may be something in between a true tubeless rim and a Snowflake in that there is  something of a hump but the angles of the slope are still wrong. Someone with an LS will know better.
caci
« Reply #18 on: February 25, 2010, 03:50:48 PM »
I am only concerned with LS Wheels at this time.
Anyone?
« Reply #19 on: February 25, 2010, 03:56:26 PM »
Anyone?
Get a picture of your wheel when the tires are being replaced!
« Reply #20 on: February 25, 2010, 04:33:00 PM »
Anyone?
LS rims came from the factory with tubes installed, I would continue using them, no matter if you install tubeless tires or not .
caci
« Reply #21 on: February 25, 2010, 05:02:34 PM »
Anyone?
(Un)fotunately, we dropped off the wheels and the tires have been replaced.
Arrgghhh! Arrgghhh! Arrgghhh!
« Reply #22 on: February 27, 2010, 12:37:44 PM »
Barry,
Thanks for the photo! It is now a world clearer just where the fabled hump is on the rim profile. As I recall the LS rim is different than the snowflake but still has no "hump".
« Reply #23 on: February 27, 2010, 02:00:30 PM »
Hmm I thought the LS wheels were tubeless.
I know the snowflakes must have tubes (I would never dream of running them without).
Well darn.   :-?
chewy4x4
« Reply #24 on: March 23, 2010, 10:45:57 AM »
Just run tubes in all of your tires regardless if they a made for them or not it makes no differences and it will give you that little peace of mind.
