Author Topic: Drop the Needles?  (Read 1895 times)
Drop the Needles?
« on: February 18, 2010, 12:27:22 PM »
Getting Gertie ready for the big ride ive pulled the plugs and done the valve clearances (they were tight) the plugs are black and sooty but not oily so im thinking of dropping the needles a notch but would the clearances effect the combustion ?.
I used a bit of carb cleaner on the plugs and they cleaded up well.Hanyes says try a hotter plug im on BP6es any thoughts.
« Last Edit: February 18, 2010, 12:33:30 PM by Lucky_Lou »
Re: Drop the Needles?
« Reply #1 on: February 18, 2010, 01:39:28 PM »
Don't think so Lou
Dropping the needles one notch is a big change and at this time of year may make Gertie decidedly cold blooded.  Maybe worth a try though as those plugs do look black. I'll be very interested to hear about the effect it has. A rich Idle mixture and use of the enricher are just as likley to blacken the plugs.
BP6ES plugs are about right for moderate use in fact thay are already one grade hotter than NGK recommend.  I wouldn't risk going any hotter still.
« Last Edit: February 18, 2010, 02:21:02 PM by bhodgson »
JDS
« Reply #2 on: February 18, 2010, 04:01:41 PM »
after you clean them up run it at speed then kill the motor coast to a stop and check it. maybe its just rich at Idle or low speed. I usually only check plugs under load at the speed I normally ride.
bruce_launceston
« Reply #3 on: February 18, 2010, 04:52:57 PM »
I think I would try leaning out the mixture screws first, as Barry said 1 notch is a big change.
I would also do a high speed 'plug chop', as JDS says, to see if the plugs clean up.
« Reply #4 on: February 18, 2010, 05:59:05 PM »
Ride her for awhile and then recheck the plugs. Your tight valve clearances may have been part of the sooty-ness.
Tv
« Reply #5 on: February 18, 2010, 10:50:59 PM »
I had a similar chronic problem doubled with a midrange loss of power and it was obstucted air intake that caused the problem.
« Reply #6 on: February 19, 2010, 07:16:37 AM »
I had a mid range stutter that was cured by dropping the needles one notch.  However I am not running a standard airbox nor am I running a standard exhaust (headers are standard though) - so all bets are off.
Steve H
Offline steven m
« Reply #7 on: February 19, 2010, 10:21:56 AM »
If you have been doing a lot of city driving in cold and damp conditions with the choke on to start and not really getting up to operating temperature that could be contributing to your sooty plugs.  Take the bike out for a sustained run, ten miles over 4500, and get it nice and hot before pulling the plugs again and if possible pull in the clutch, drop it into neutral, and shut off the engine with no compression braking before pulling the plugs.  That will give a more accurate indication of your carb set up.
I wouldn't change anything on your carbs until you have tested it with reset valves.  Carbs are really tempting to adjust but aren't always the first place to start.  And in this case, apparently running too rich is much better than running too hot and burning something up on your trip.
Steve
« Reply #8 on: February 19, 2010, 10:41:21 AM »
Steve
Thats a valid point bearing in mind im not using addatives in the fuel theres a memorial ride from squires on sunday about 70 mile RT ill check em on the way back before i tweek the needlesthanks for all the input.
« Reply #9 on: March 10, 2010, 11:28:24 AM »
Just rechecked the plugs having done a few "longer" rides all seems ok must have been the shorter journeys and use of choke causing the problem as ive not adjusted anything.
« Reply #10 on: March 10, 2010, 02:50:58 PM »
How much choke do you use Lou?  I've done nothing but short 3.5 and 4 mile commutes to work through the winter and it hasn't blackened the plugs. I don't ride on the choke though. Start on full choke, back off to half way as soon as it fires then off altogether within a minute or two before setting off. You would think it must be running too rich to be able to do that and maybe it is but I won't change anything till the weather warms up a bit.
BTW I envy you guys with a handle bar mounted choke lever. It's a 3 act farce starting on full choke with the left hand pulling in the clutch out of sympathy for the battery and then having to move down very quickly to get the choke off full before it stalls. No way will the engine run on full choke even at  -8 Deg C
« Last Edit: March 10, 2010, 03:37:18 PM by bhodgson »
« Reply #11 on: March 10, 2010, 04:56:52 PM »
I usualy use full choke for about 1/4 mile back it down to 1/2 then at about 1 mile knock it off.If it starts popin and fartin on reducing revs i knock it off sooner the shortest journey i do is about 5 miles up to my workshop but thats J39 to J40 on the M1 mostly im out for the day.It starts and ticks over from cold with no problem at all.Usualy about 1300 rpm with choke 1100 without.
« Last Edit: March 10, 2010, 04:59:32 PM by Lucky_Lou »
« Reply #12 on: March 11, 2010, 03:24:11 AM »
It ticks over on full choke ?
Mine won't run for more than a few strokes on full choke. Is anybody else able to tickover on choke like Lou?  It would be interesting to have a definitive  description of what the choke is supposed to do.
BTW Lou and I and everybody else knows it's not really a "choke"  we just just substitute that word for enricher or starting carburettor.
bruce_launceston
« Reply #13 on: March 11, 2010, 04:45:57 AM »
Stone cold I use full choke until it starts, then off to 1/2 choke for maybe 30 seconds then fully off after riding only about 100 metres.
Daytime cold restarts no choke or maybe 1/4 if it doesn't fire straight away.
« Last Edit: March 11, 2010, 04:46:20 AM by bruce_launceston »
plc
« Reply #14 on: March 11, 2010, 02:01:46 PM »
Hi All,
I am not sure if my choke (enricher) works properly. When my bike is cold (anything more than 4 hours stationary, it needs full choke to start. I then leave it on full choke for a minute or two while I put my helmet and gloves on then turn it off before I drop it off the centre stand. If I have full choke on when I drop it off the centre stand it starts to stumble.
My bike will never run on the 1/2 choke mark for more than a few seconds, so I never use it.
Maybe one choke disk is blocked because one has been off and cleaned when I replaced an o-ring on the shaft.
Best to all,
Paul
