Author Topic: Carbs out of balance 3 times in 2 weeks?  (Read 1683 times)
Online Bob_Roller
Re: Carbs out of balance 3 times in 2 weeks?
« Reply #15 on: March 05, 2010, 06:58:24 AM »
I tried a mod on the crank case breather valve, remove the valve housing from the engine case, place a portion of a copper pot scrubber pad into the top of the housing, not enough to block it off .
Then re-install the housing .
Seems that a lot of the oil comes out in an atomized state, the pad gives it something to collect on, then drain back into the sump .
