Author Topic: Butterfly screws  (Read 2876 times)
Re: Butterfly screws
« Reply #15 on: February 02, 2010, 03:38:12 PM »
You are supposed to grind off the peened end of the screw with a rotary-type tool before attempting to remove them.
Yep.  You can also use a file, if you have one narrow enough to fit easily through the carb bore.  The soft metal of the screws files off pretty quickly.
« Reply #16 on: February 02, 2010, 09:41:17 PM »
Cool discussion as it looks like I'm about to do this.
bruce_launceston
« Reply #17 on: February 03, 2010, 01:40:07 AM »
Hi Rob
Bought my LS with only 2000km on it, wasn't even run it.
It just kept getting better and better.
« Reply #18 on: February 03, 2010, 01:46:02 AM »
That is nice to find a bike that one or many previous owners have not made "their own"!
bruce_launceston
« Reply #19 on: February 03, 2010, 06:27:13 AM »
The original owner didn't give it a fair chance, he must have only kept it a couple of months. Apparently he bought a Harley after trading the R65LS back to the BMW dealer.
It sat in the dealership for a few months before I traded my Honda CB1100F in on it. (I couldn't afford to keep tyres on the couple of big jap bikes I owned before I bought the BM.)
As I said earlier I remember it loosening up as it was 'running in', it now has nearly 92,000 km on it and still has never had the heads off....
but it's had 1 timing chain, 3 new batteries, 2 rear main seals, 1 alternator rotor rewind, 1 gear shaft seal, 1 pinion? seal, 10 rear tyres, 6 front tyres, 2 master cylinder kits, 2 sets of brake pads, 1 rear brake shoe reline, 2 sets diaphrams, 1 set needles and seats, 3 air filter elements, 2 clutch cables, a few throttle cables, 1 speedo rebuild, 1 new exhaust system, 1 new sidecover, 1 set new brake rotors, 2 resprays, 2 seat recovers and a few other odds and ends.
« Last Edit: February 03, 2010, 06:31:59 AM by bruce_launceston »
Offline wilcom
« Reply #20 on: February 10, 2010, 09:15:45 PM »
I have the Bing video on rebuilding their carbs and they say multiple times to PEEN the screws and DO NOT trust Loctite to hold them in place.
 When that screw does come lose guess where's it gonna go?   Yep........now think how long it's gonna be in there before it spits out the exhaust port.......... not a pretty picture!
Considering the damage that can occur,  I'd play by the rules on that one!
Of course that's just my $0.02
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #21 on: February 11, 2010, 04:06:02 AM »
I must admit I would have been tempted to use loctite but I recently read on the Airhead list that Tom Cutter has known loctited butterfly screws to come out and cause engine damage.
