Author Topic: Brakes  (Read 5836 times)
Re: Brakes
« Reply #15 on: April 05, 2007, 02:38:25 PM »
You don't need to put thread tape on, the sealing surface is the conical surface of the bleeder screw to the countersunk surface of the caliper.
Offline BooG
Re: Brakes
« Reply #16 on: April 06, 2007, 03:46:28 PM »
Glad I did the calipers! Check out the chocolate!!
What about the crap seals I got sent in a Brembo repair kit?! A dust cover short as well.
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Offline BooG
Re: Brakes
« Reply #17 on: April 06, 2007, 03:50:03 PM »
Nasty
BMW R65 1980.
BMW K75S 1987
Re: Brakes
« Reply #18 on: April 06, 2007, 04:02:08 PM »
It sometimes helps to tape the threads if you are bleeding with a Mity-Vac, or similar...  Why are you replaceing your pistons?
« Last Edit: April 06, 2007, 04:03:17 PM by admin »
Re: Brakes
« Reply #19 on: April 08, 2007, 01:20:18 PM »
+1 on taping the threads as I use the Mity-Vac as well!
Offline BooG
Re: Brakes
« Reply #20 on: April 09, 2007, 04:28:03 PM »
I'm not replacing the pistons in the calipers...just cleaned em up a bit and am putting in new seals/pads/bleed nipples/dust covers.
When I bleed brakes, I just use a length of clear pipe at the correct gauge, and a jar with some brake fluid in. What's a Mity Vac then? Is that a bleed kit?
BMW R65 1980.
BMW K75S 1987
Re: Brakes
« Reply #21 on: April 09, 2007, 05:07:27 PM »
Boo,
When you wrote, "...seeing as they're coming off again, to do a brake overhaul.. pistons as well!...", I assumed you were having to replace the pistons for some reason.  My mistake...
A Mity-Vac is a hand operated vacuum pump that, with a bleeding cup attachment, can be used to bleed cantankerous brake systems.  But, like you, I usually dangle a chunk of hose into a jar with a little fluid in the bottom and pump away.
« Last Edit: April 09, 2007, 05:07:49 PM by admin »
Offline BooG
Re: Brakes
« Reply #22 on: April 11, 2007, 02:31:09 AM »
Excellent! I like low tech solutions!
I got a satchet of grease in the caliper repair kit...what is this used for? Do you put it on the rubber seals and the O rings?
BMW R65 1980.
BMW K75S 1987
westfalian_alien
Re: Brakes
« Reply #23 on: April 11, 2007, 05:13:58 AM »
Boo,
Yes.
Drive safely
westfalian alien
