Author Topic: Loosening the R65 swing arm  (Read 3351 times)
Re: Loosening the R65 swing arm
« Reply #15 on: January 05, 2010, 04:47:17 PM »
BMW has a grease/lubricant specifically for transmission input splines, it's Microlube GL 261 .
BMW wants about $18US for a small tube of it, I think it's about 10ml worth of material .
« Reply #16 on: January 05, 2010, 06:13:28 PM »
Two recent -as in yesterday- small setbacks have slowed progress. Plus, it's gotten colder than a well digger's belt buckle around here. Even the KeroSun shop heater is having trouble keeping up.
I was confident that my large selection of metric O-rings would contain the size I needed for the rear brake cam shaft. Wrong. A Monday morning call to John at Bench Mark Works in Sturgis -the good one... in Mississippi- got a handful on my way. http://www.benchmarkworks.com/ BTW, the O-rings are 10 x 2 mm if you'd like to score a couple for future use.
Second issue was my modified Lowe's 27mm socket. I had machined the face of the socket so that it would fully grip the swing arm nut. Checked it on the right side of the R65 and we're good to go. Well, I loosened the left side OK but I have concerns about it's grip; I had previously read about BMW's variances in the machined 'well" that houses the nut. Oh, Snap! Joe's Tools http://www.culayer.com/Joes_tools.htm up Illinois way is sending me one of their turned down wall and face sockets.
At any rate, I'm ready to do the spline lube. Then, I'll need to refit the rear wheel, with the new brakes shoes and O-rings- so I can hold the driveshaft while I remove the four U-joint bolts. Then, again remove the swing arm pivots and again pull back the swing arm so I can replace the busted boot.
This business just reinforces my decision to own two R65's. Work to Ride to Work to Ride. Whatever.
Watching the mailbox... impatiently. :DMonte
« Reply #17 on: January 05, 2010, 06:32:34 PM »
 Did you ever think of heading to your local NAPA auto parts store to see if they had any o-rings ?
« Reply #18 on: January 05, 2010, 06:41:23 PM »
I love NAPA. I did check. Unfortunately, struck out.   Monte
« Reply #19 on: January 05, 2010, 06:53:36 PM »
They've saved me from waiting a week or two, for some common o-rings and the like on the bikes, and cages as well !!
« Reply #20 on: January 10, 2010, 05:44:15 PM »
They've saved me from waiting a week or two...
On Monday afternoon, I spoke with John at Bench Mark Works in Sturgis, Mississippi. They had the correct O-rings and felt washers. I ordered extras of both. Bits arrived via USPS on Thursday. Fast service from a remarkable independent airhead shop.
