Author Topic: New rider from down south!! Need help!  (Read 3604 times)
Re: New rider from down south!! Need help!
« Reply #15 on: December 18, 2009, 04:29:45 PM »
Hi Remolon,
When you renew the carbs be forwarned: the idle jet is on the bottom corner of the float bowl!  Many people miss this important jet!!
Do your carbs Flat Tops or Dome Tops?
Good luck,
« Reply #16 on: December 18, 2009, 06:19:11 PM »
It is a good idea to replace your fuel hoses periodically.  I like the old stuff BMW provided, so I replace mine every 2-3 years.
You should also drain the fuel tank and remove the petcock to check out what kind of dirt there might be in there, as well.  I do this every year when putting it up for the winter.
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #17 on: December 18, 2009, 06:21:28 PM »
remolon,
Best of luck on the carb rebuild.  Here's some picture links for you if you need them. Lots of carb experience on this forum if you have any questions while you're into them.
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Bing%20Carb%20Left/
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Bing%20Carb%20Right/
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
Darwin_R65
« Reply #18 on: December 30, 2009, 05:23:21 AM »
Remolon good luck with your bike, many friendly people here with good technical knowledge.
By the way you're North from me in Australia
John  :)
