Author Topic: Does your r65 tachometer take smoko breaks??  (Read 3826 times)
Re: Does your r65 tachometer take smoko breaks??
« Reply #15 on: May 12, 2009, 06:40:31 AM »
Thanks Bob
I have the earlier diagram and can now see the the circular mutipole connector it just isn't labelled as the tacho.  Connection numbers are the same.
I agree the steering bearings should not be needed as a ground path and therefore still don't understand Moto-bins comment. I wonder if anyone has actually had this problem.
rob650
« Reply #16 on: May 12, 2009, 11:45:08 PM »
My tach needle zings all over creation beyond 4000 rpm.  Ill see if the ground wire mentioned here helps at all.
ambrose78
« Reply #17 on: December 01, 2009, 11:06:54 PM »
Well as time goes on my tacho seems to be having more and more time off.
It is also developing a hyperactive disorder above 3-4000 rpm mark.
I have run an additional grounding wire to the instrument binnacle but it has made no difference to the tacho's operation.
This makes me think it is the instrument rather than the wiring.
Has anyone had any luck repairing an R65 tacho?
Anything specific to look out for?
cheers
bruce_launceston
« Reply #18 on: December 02, 2009, 06:06:47 AM »
My tacho has always worked fine but my speedo had almost exactly the same symptoms as your tacho.
I had it rebuilt many years ago and it eventually started get dodgy again, I was about to send it away to get fixed again but when I took it off, I gave it a shake, put some grease on the nylon gears, gave it a run on the electric drill and put it back on, it's been as good as new ever since. Beats me ...
« Reply #19 on: December 02, 2009, 08:23:03 AM »
The electrical 'signal' for the tachometer, comes from a wire that comes off of the ignition coil .
If your wire, and connections are good, it's a good chance there is a problem with the printed circuit board inside the tachometer .
There have been problems with the solder connections, and the pc board itself cracking causing a 'nervous' needle .
« Last Edit: December 02, 2009, 08:23:34 AM by Bob_Roller »
