Author Topic: Under tank buzzer question  (Read 2677 times)
Re: Under tank buzzer question
« Reply #15 on: October 28, 2009, 04:39:26 PM »
The electrical switch that's activated by the clutch lever, allows you to operate the starter when the transmission is in gear .
Not to cancel the turn directionals .
But it also silences the buzzer if you are sitting at a light in gear, with a turn signal on, and the clutch pulled in.
Let out the clutch, and the buzzer starts in again, until you cancel the TS (or pull in the clutch...).
