Author Topic: Supplemental Lighting  (Read 5194 times)
Re: Supplemental Lighting
« Reply #15 on: March 25, 2007, 10:33:38 PM »
There is a new Brushless Alternator that comes on sooner than the Omega/Bosch Alternator.  I think it is rated at a slightly higher amperage than the Omega.  This is if you are happy with your stock ignition and are not going to need the Omega Crankshaft fired ignition.  It requires the Bosch Alternator housing to mount.
The Brush less Alternator will also work when the GEN light bulb burns out.
« Reply #16 on: March 25, 2007, 11:03:36 PM »
The system is called the Endurolast charging system, Euro Motoelectrics in Monument , Colorado has the system ready to install . A  less expensive system than the Omega and a little more wattage output.
« Last Edit: March 25, 2007, 11:06:11 PM by Bob_Roller »
