Author Topic: Gasket Ring?  (Read 1290 times)
Crossrodes
Gasket Ring?
« on: September 01, 2009, 06:14:34 PM »
While I'm waiting for my Allen socket for my steering I decided to tackle a couple of other issues with the bike ('79 model).  There is a switch on the bottom of the transmission...I'm guessing it's the neutral switch.  Oil is leaking from around this switch.  Several questions...
1. It is located in a very awkward place...can it be removed and re-installed without engine removal?
2. The parts diagram calls the seal a gasket ring...Is is truly gasket material or is it an O ring?
3.  If it is an O ring does anyone know the size?  Rather than ride 100km to the BMW store (after I wait a week for them to obtain the part) I'd prefer to buy it in a local parts store and get it installed right away.
Re: Gasket Ring?
« Reply #1 on: September 01, 2009, 06:30:32 PM »
It's a royal pain to replace the neutral switch with the transmission installed, but it can be done .
You need to remove the rear engine mount stud, and the large aluminum spacer that sits between two ears of the engine case .
The seal on the switch, is an aluminum washer, commonly called a crush washer .
Crossrodes
Re: Gasket Ring?
« Reply #2 on: September 01, 2009, 06:40:54 PM »
Thanks Bob.
Re: Gasket Ring?
« Reply #3 on: September 01, 2009, 07:23:19 PM »
And if you do manage to remove that large spacer, it won't be easy getting it back in (as you will find out when you try to remove it.).
I think I have read of folks putting it in the freezer for a couple of hours before reinstalling.
There are two different neutral switches used on the post-1970 airheads.  They are opposite each other in function, I think.  Regardless - double check your part #.  It should be 61 31 1 243 097.  Wow!  $41 retail on Chicago's site!
The gasket # is 61 31 1 355 262.
http://www.realoem.com/bmw/showparts.do?model=0363&mospid=47851&btnr=23_0256&hg=23&fg=05
Re: Gasket Ring?
« Reply #4 on: September 01, 2009, 07:49:42 PM »
If you bevel the edges of the spacer, and cool the spacer,n it will ease the installation, last time, I used dry ice, and the spacer slid right in, no problems .
But It's pain in the butt, however you look at it .
Crossrodes
Re: Gasket Ring?
« Reply #5 on: September 01, 2009, 11:21:01 PM »
Guys thanks for all the info.  Since I just got the bike licensed and on the road I think I'll wait for the fall/winter to tackle this one.  I don't know the status of the spine lube so I'll probably just pull the transmission and do the switch/washer at that time.
Oh yes...I never did find all the timing marks on the fly wheel so while I've got the transmission out I'll see if I can get at the flywheel, clean it up and mark the timing marks properly... As a matter of fact if all goes well my plan is to pull the engine out and get the frame powder coated.
Right now I've done a rough timing job and have set it the timing up so that it idles around 800 rpm.  I haven't heard any pinging so hopefully I haven't got it advanced to where it will do any damage.
« Last Edit: September 01, 2009, 11:28:51 PM by Crossrodes »
Yikes
Re: Gasket Ring?
« Reply #6 on: September 02, 2009, 09:47:13 AM »
Does anyone know if it is the switch itself that leaks and needs to be replaced or will just replacing the gasket ring do the job? :-/
Re: Gasket Ring?
« Reply #7 on: September 02, 2009, 10:27:47 AM »
If your switch has a plastic body, as does the oil pressure sender, the plastic could be damaged.    Monte
Re: Gasket Ring?
« Reply #8 on: September 02, 2009, 10:30:59 AM »
The usual scenario, is that the transmission lube seeps through the switch .
I was told by the local independent BMW shop, that the switch should not be installed any tighter than hand tight, with some sealant applied to the threads before installation .
Apparently the design of the switch is not the greatest, and if you over tighten it with a wrench, the plastic innards of the switch break quite easily, then the seepage will start with time .
Crossrodes
Re: Gasket Ring?
« Reply #9 on: September 02, 2009, 10:54:40 AM »
Good info.  It sounds like the switch itself could be the cause of the leakage then.  I guess just have to bite the bullet on price (Chicago BMW told me they won't ship to Canada so I'll probably have to pay more somewhere else)
Re: Gasket Ring?
« Reply #10 on: September 02, 2009, 12:34:11 PM »
Moto moto moto bins!  Good prices and good service.  Check 'em out.
www.motobins.co.uk
