Author Topic: Near total loss of power  (Read 2795 times)
Offline R65Guy
  • I'd rather be ridin'
Re: Near total loss of power
« Reply #15 on: June 10, 2009, 08:03:31 AM »
Pierre,
Here is some good reading on diaphragms and Bings in general.... and those dreaded dome screws.  Before you start reading, go put some penetrating oil on those dome screws and let it begin to soak.  If they come loose easily the rest of the job is not difficult.  The screws have a broad tapered head that is prone to seizing to the dome.  Using a screwdriver with the tip ground down a bit might help keep the screwdriver from slipping.  Those are not normal phillips screws.
http://bmwmotorcycletech.info/bingcv.htm
http://bmwmotorcycletech.info/bingcv-2.htm
Neal
81 R65 & 16 R1200GS
« Reply #16 on: June 10, 2009, 09:25:42 AM »
I have never had any problems getting those screws out by using a hand impact.
« Reply #17 on: June 10, 2009, 10:00:24 AM »
Using valve grinding compound on the screwdriver improves the 'grip' of the bit, to help prevent rounding out the screw head .
Worse case scenario, you can drill out the screw, and use a screw and nut .
When you get the screws out, I would recommend using stainless screws after that, the metric thread, and SAE 10-32 are compatible .
« Last Edit: June 10, 2009, 10:03:30 AM by Bob_Roller »
pierre
UPDATE: Near total loss of power
« Reply #18 on: June 11, 2009, 04:07:59 PM »
I just removed the carb domes and removed the diaphragms to determine the one with a tear.
Should I be able to see the tear?  I gently stretched the diaphragms all around and cannot see any tear or hole.
« Reply #19 on: June 11, 2009, 04:14:36 PM »
A pin-hole could be enough to affect it, or a bad seal around the inside diameter or the outside.  But the ID seal should have been apparent to you, and the OD should not have changed abruptly without being disturbed.
Check it with a bright light if you have not already done so.  (shining from "behind" the diaphragm)
I guess we need to move on to other possibilities.... :(
Did you check your float bowls and fuel flow?
pierre
« Reply #20 on: June 11, 2009, 04:56:32 PM »
Yes, both bowl were holding gas. The gas was clean, without debris. The floats moved freely.  And with the petcock switched to the on position,  a steady trickle of gas flowed.
Just looked at the diaphragms over a light and didn't see any holes.
pierre
« Reply #21 on: August 10, 2009, 07:46:07 PM »
not have this thread open ended, here's the final resolution.
You'll be surprised . . .
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1249863188
