Author Topic: Seat Tether  (Read 1794 times)
Seat Tether
« on: August 06, 2009, 10:39:41 AM »
Much time and energy during my summer break from school has been devoted to maintenance and cosmetic issues for both the R65s.
Blackie, the 1981, got the Bings overhauled, a relay-operated new horn, timing chain, stator brushes, a new AGM battery, and the SueCanada mod.
the 1983 Mexico Bike received most of my attention with a new Dyna coil with plug wires and caps, seat cover, fuse box upgrade, and the hefty time-consuming job of body work repairs and paint job.
One item continued to disturb me and that was an issue where the seat edge, when opened, bumped the right rear shock and the right battery cover. Perhaps the slightly deeper seat edge created by the installation of the nylon U-channel upholstery guard contributed to the contact.
Anyway, I developed serious concerns about the potential of damage to the seat cover and the freshly rehabbed battery cover.
This morning, I spent not more than thirty minutes fabricating a tether to hold the seat in an over-center position but just short of contacting the shock and battery cover. Now, rather than trying to remember to be cautious when opening the seat, the tether does it for me.
Approx 12 inches of 1/32" stainless steel cable, two 14-16 ga ring ends sized as required, and some shrink tubing were all on hand. Measure and build took maybe ten minutes max.
An existing hole in a frame gusset became an anchor point for one end of the tether. The seat pan was drilled and a stainless screw captures the other end of the cable.
Still need to touch up that rusty area near the front hinge. Ugly.
ambrose78
Re: Seat Tether
« Reply #1 on: August 06, 2009, 06:15:16 PM »
Looks nice Monte!
Out of curiosity - What is the SueCanada mod?
Re: Seat Tether
« Reply #2 on: August 06, 2009, 06:59:35 PM »
...Out of curiosity - What is the SueCanada mod?
Check out the "Leaky Rear Drive" thread a couple notches down from this one in "Tech".
Sue was the first to mention the mod here at Disorganized R65ers.
Re: Seat Tether
« Reply #3 on: August 06, 2009, 08:30:46 PM »
You know a little naval gelly (leave your shirt tucked in Monte, it comes in a bottle) would work wonders on that gross corrosion under your seat.  All in all, I'd say you're a very clever fellow.  Did you get the idea from the retractable wire on your wallet? [smiley=bmw_smiley.gif]
Altritter
Re: Seat Tether
« Reply #4 on: August 06, 2009, 09:55:59 PM »
Damn, Monte, you could be making a fortune being the problem-solving brain behind some entrepreneurial jerk's bravado! But then, when would you have time time to ride? [shrug] Good show!
Re: Seat Tether
« Reply #5 on: August 07, 2009, 07:23:35 AM »
You funny, Yankee fryboy. Just lucky that I can get a free beer at your house once in awhile or I'd come up with some snappy retort!
 [smiley=beerchug.gif]Monte
weasel01
Re: Seat Tether
« Reply #6 on: August 07, 2009, 08:49:25 AM »
Hey, that looks like a problem solved!
Re: Seat Tether
« Reply #7 on: August 07, 2009, 11:42:05 AM »
It needs to be sand-blasted and repainted.  I'd let him use my blaster, but, I AIN''T GOT NO FREAKIN' SAND!!!!!!!
« Last Edit: August 07, 2009, 11:42:41 AM by admin »
ambrose78
Re: Seat Tether
« Reply #8 on: August 07, 2009, 07:15:15 PM »
Gotcha  ;)
Re: Seat Tether
« Reply #9 on: August 08, 2009, 06:45:47 PM »
Those things are stock on my Triumph.  Of course, mine is missing, but I'm supposed to have one.
I'm just gentle when I lift the seat.
Re: Seat Tether
« Reply #10 on: August 09, 2009, 06:33:35 AM »
...I'm just gentle when I lift the seat.
Right. I usually remember to be "gentle" about the time the shock and seat edge make hard contact.   Monte
