Author Topic: Can we resurface the brake rotor?  (Read 828 times)
rob650
« on: April 28, 2009, 05:18:11 PM »
Hi Everybody,
Rebuilding my caliper + new pads soon, and thought about getting the rotor resurfaced.  Mine looks in good condition without major grooves, though not "mirror" flat if you run your hand over it.  I don't have the funds for a new rotor right now.
I've never heard of doing this to a bike rotor and wanted to ask.  I know car rotors have minimum thickness limits for the purposes of resurfacing, do ours?
Thanks
Rob
Re: Can we resurface the brake rotor?
« Reply #1 on: April 28, 2009, 05:56:24 PM »
The rotors are stainless steel, and very difficult to true up on a lathe, .180 in. is the minimum rotor thickness.
There a few after market rotors available, I've got EBC iron semi-floating rotors, and EBC graphite pads, and while the dry stopping doesn't appear to be noticeably increased, wet braking is greatly improved over stock rotors and pads.
« Reply #2 on: April 28, 2009, 06:07:47 PM »
I recommend saving your money for a new rotor.
Yours will probably be serviceable for some time, yet.
I ran mine for a long time with pronounced grooves, and it still stopped me well.
I replaced it with a EBC like Bob.
« Reply #3 on: April 28, 2009, 06:27:00 PM »
...I ran mine for a long time with pronounced grooves, and it still stopped me well...
X2 for Bob's comments. [smiley=thumbup.gif]
My '81 has definite grooves in the front rotor. The brakes pads will wear/bed in to a conformation with the rotor and will stop you pronto.
Milling the rotor is a waste of time and money as the stainless steel rotors, once well grooved, will afterwards be too thin for safe operation. Fugitaboutit.
My '83 has a new rotor and I'll be dipped n' clipped if I can tell a difference in braking performance.
Now, if only I could do something about the old school-quality braking of the rear shoes. :(
« Last Edit: April 28, 2009, 06:28:00 PM by montmil »
« Reply #4 on: April 28, 2009, 06:57:38 PM »
When I finally replaced my rotors, the high spots on the rotors were at .180 in., with .060 in. deep grooves on each side.
I had about 79,000 miles on the rotors before replacing them.
There's a company, I believe it's Spiegler, that will drill out the rivets on your OEM rotors, and replace them with stainless semi-floating rotors, for about the same price as aftermarket rotors.
http://www.spieglerusa.com/BMWConversions/
« Last Edit: April 28, 2009, 07:05:59 PM by Bob_Roller »
