Author Topic: Bing parts $...Good Lord!  (Read 4704 times)
Yikes
Re: Bing parts $...Good Lord!
« Reply #15 on: April 11, 2009, 11:59:31 AM »
So Monte, what all did you end up ordering from Motobins for your carb overhaul?
John M
« Reply #16 on: April 11, 2009, 05:48:29 PM »
John and others...
I had on hand the new diaphragms and a kit of the needed O-rings, enrichment valve gasket and the float bowl gasket. Earlier, I mentioned these came from Flugelnus http://www.flugelnus.com/ but I was in error. My records show they were outta Chi-Town BMW. Better prices.
MotoBins supplied the following bits... Some may be unnecessary but the carbs are as yet unopened so better safe than stopped:
Carb Top Screw (4)
Carb Mixture Tube, 32mm threaded (2)
Carb Main Jet Washer (2)
Carb Vacuum Take-Off screws (2)
Idle Mixture Screw 1970> (2)
Float Assembly 1970> (2)
Float Retaining Pin (2)
Float Needle (2)
Slide Needle 32mm 70-84 (2)
Idle Jet #40 (2)
Needle Jet # 2.66 (2)
Parts = 81.50 British Pounds - $117.00USD (about half what Bing NA wanted for their kits)
Air Carriage = 7.50 British Pounds - $10.98USD
1 British Pound = 1.46492 US Dollar as of 11 April 2009
Bob's BMW also has individual Bing parts but not anywhere close to the vast parts listing at M-Bins.
« Last Edit: April 11, 2009, 05:53:35 PM by montmil »
« Reply #17 on: April 11, 2009, 05:59:19 PM »
Monte,
A little late now, but you can use stainless countersunk AN, or NAS, 10-32 screws for the carb top, use the ones without any unthreaded shank.
They are a perfect fit !
« Reply #18 on: April 11, 2009, 06:02:15 PM »
Monte, A little late now, but you can use stainless countersunk AN, or NAS, 10-32 screws for the carb top, use the ones without any unthreaded shank. They are a perfect fit !
Never too late, Bob Robert, and thanks for the tip. I have a tub full of 'em in a variety of lengths. I like the cad finish so will save the others. MotoBins sells 'em cheap so it's all good.[smiley=thumbsup.gif]
« Reply #19 on: April 11, 2009, 10:43:26 PM »
10x32 is a perfect fit?  I coulda swore that screw was an M5x.8...
Darwin_R65
« Reply #20 on: April 12, 2009, 04:45:43 AM »
10x32 is a perfect fit?I coulda swore that screw was an M5x.8...
If force doesn't work........you're not using enough.
« Reply #21 on: April 12, 2009, 07:16:33 AM »
Just get a bigger hammer!
« Reply #22 on: April 12, 2009, 08:06:14 AM »
I had no problem installing them.
I don't remember the diameter and thread pitch, but when I had my carbs apart about 12 years ago, the OEM steel screws were in bad shape, and they looked like they were close to a 10-32 screw, tried them and they worked.
I did some calculating, and when I got all the dimensions, there was only a few thousandths of an inch difference in diameter, and thread pitch.
« Last Edit: April 12, 2009, 08:54:01 PM by Bob_Roller »
« Reply #23 on: April 12, 2009, 09:38:25 AM »
Some you'z guys may have these helpful Bing carb overhaul sites bookmarked, but for dems dat don't:
http://largiader.com/tech/carbs/
http://gunsmoke.com/motorcycling/r100gs/carb_rebuild/index.html
Very helpful in motivating yourownself to get the job done.   Monte
« Reply #24 on: April 12, 2009, 10:14:43 AM »
Bob, interesting...
« Reply #25 on: April 12, 2009, 02:55:29 PM »
...Very helpful in motivating yourownself to get the job done. Monte
Quoting myself here. Of the four cross-point screws holding the carb tops onto the body -two screws per carb- one was totally cammed out by a PO and rusted up tight as a tick.
This morning, it was pretty simple to center up a bit and drill out the head using progressively larger bits. A small, tapered stone on the Dremel finished up the screw head removal without boogering up the carb top, as in mucho $$$.
Will remove the remaining threaded portion of the screw when the cables are removed along with the tops. So now I'm really motivated to overhaul the Bings as I can't ride without the screw! Plus, the '83 is apart for paint.
My day job is getting in the way of my fun jobs.
Happy Easter from a wet, chilly and almost burned up North Texas. Couple days of grass wildfires burned off 140,000+ acres plus and 100+ buildings/homes in the county just N'West of us. Luckily, all we got was smoke irritated eyes.
« Reply #26 on: April 12, 2009, 03:11:56 PM »
Mentioning buggering up the threaded hole on the carb body side, I've seen the hole drilled out , and a screw and self locking nut used instead.
« Reply #27 on: April 12, 2009, 03:41:57 PM »
That thought crossed my mind, Bob, just as the bit tried to "grab".  :D
« Last Edit: April 13, 2009, 05:38:39 AM by montmil »
« Reply #28 on: April 12, 2009, 07:02:56 PM »
I have always used a hand impact for getting these screws out and it's never let me down.  I always replace them with stainless steel allen head screws...
« Reply #29 on: April 12, 2009, 07:11:20 PM »
That's what I did, and I used anti-seize as well.
