Author Topic: Speedometer Repair  (Read 6463 times)
Re: Speedometer Repair
« Reply #15 on: March 17, 2009, 08:36:41 AM »
I love my Vapor digital instrumentation installed on the '81.  $124.95 and made in the USofA.  If the '83s instrument pod wasn't in perfect physical and operational condition, it would have one, too.   Monte
Yikes
« Reply #16 on: March 17, 2009, 09:53:10 PM »
Re-Psycle in Ohio also do speedo refurbs for (I think I recall) $180 plus parts, usually totalling in the $220 range, about in line with the other shops.  I've gotten some good deals from them on used parts and they seem like a good outfit.
But take heart, after convincing myself that a working odometer is a luxury item that I was being extravagant to want, I was lucky and snagged a used one with less than 15,000 miles on Ebay a few weeks ago for less than $75.  Even the trip meter works, which never did on my old one.  Just need to figure out some repair on the little rubber cover which is split in a couple of places.  I'm thinking of finding a small plastic cap of some sort to just cover it up and only uncover it to re-zero it, which, like the one on my Volvo, is never.
« Reply #17 on: March 18, 2009, 01:15:24 AM »
Yikes, if your Volvo odo doesn't work (depending on model) there is a gear that goes bad in it that costs about $25.  The odo in my '93 240 hasn't worked for about 3 years...
« Reply #18 on: March 18, 2009, 07:10:02 AM »
"I love my Vapor digital instrumentation installed on the '81.  $124.95 and made in the USofA."
Monte, do you have a photo of the Vapor on your bike?
« Reply #19 on: March 18, 2009, 08:03:25 AM »
Hey Bengt. Just scroll up a couple threads and take a looky see!  :-?
Also, use the search feature for Vapor. About a year ago. Lottsa pics for you.
« Reply #20 on: March 18, 2009, 03:50:16 PM »
Thanks Monte, I'll do the search.  For some reason, probably my laptop or firewall, doesn't show the pictures a lot of the time, even when I allow popups.  I did look at the Vapor on line and it looks like a great little device.  How to make a nice display with the ignition system after removing the original tach and speedo is what I'm after.
« Reply #21 on: March 18, 2009, 04:29:07 PM »
« Reply #22 on: March 18, 2009, 07:39:40 PM »
Hey, on my little old refurbished laptop I can see the photos clearly.  Must be the firewall at the office trying to keep me from doing constructive work that blocks the cool stuff.
Judging from the handiwork you must be related to McGiver.  I'm curious about where the ignition key is.  Given your mechanical abilities I'm sure you could hotwire anything but I kind of doubt that's what you do.  So where did the ignition key go?
« Reply #23 on: March 18, 2009, 07:53:53 PM »
...So where did the ignition key go?
The original instrument cluster had an ignition switch and key cobbed together out of a riding lawnmower. I swear. Nasty.
OK, so now you and all the other cats 'round this site will know where my"key" is. The little weatherproof blue boot... All ignition wiring is tucked into the headlight shell. Old school.  Use caution. Rider carries.  [smiley=rifle.gif]
