Author Topic: how do i check final drive oil level? there are 3 openings.  (Read 4218 times)
Offline davenerk
i am sure this is a common question but even though i found references to it, i did not find the answer.  i changed the final drive oil yesterday, drained it and added back 350cc.  the clymer manual and the internet mention looking in the hole and checking the level and measuring from the lip of the hole down to the oil.  they cant mean the drain plug, and i dont think they mean the vent.  but the bolt in the straight back isnt similar at all to the allen head bolt that sits horizontally in ALL the pictures i could find.  could someone just set me straight?  where and how do i check level?
Re: how do i check final drive oil level? there are 3 openings.
« Reply #1 on: June 28, 2026, 04:51:08 PM »
The plug on the aft side of the final drive.
Fill i until oil comes out .
Offline davenerk
« Reply #2 on: June 28, 2026, 07:47:33 PM »
just to be certain.  you mean this bolt?
« Reply #3 on: June 28, 2026, 08:36:21 PM »
I am unable to see any pictures on this site
So I can't confirm it .
Offline davenerk
« Reply #4 on: June 28, 2026, 10:06:38 PM »
ok.  there are only 3.  drain cant be it, vent cant be it, aft is rear so you must meen the small hex bolt.  ill try it.  thanks.
« Reply #5 on: June 29, 2026, 01:09:16 PM »
Yes I think it's a 10 mm .
Offline Kelvin
  • R65LS
« Reply #6 on: July 04, 2026, 07:14:32 PM »
I can see pictures and, yes, the bolt you've circled in the picture is the one that sets oil level.
Incidently, I find this method messy. I measure the oil quantity in a jug and pour the correct amount in.
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
