Author Topic: Rubber bushing  (Read 3846 times)
Offline Tiedie
Rubber bushing
« on: May 03, 2026, 02:45:52 PM »
Anybody know about the rubberbushib
ng ont the crashbar that attaches to the motor? It is on the leg part under the cylinder/ infront.  Probably not worth woring about but Jake was looking at it ang we both questioned it.
Offline Burt
Re: Rubber bushing
« Reply #1 on: May 05, 2026, 10:11:19 PM »
Not quite sure what you are referring to as the photo is crap.
If it is the rubber between the engine and the frame where the crash bar rear leg attaches to the frame then that is an anti-vibration modification, as the original was a metal washer.  These deteriorate over time and need replacing but I don't think this is what you are referring to  ???  If it is something attached to the rear leg attachment nut, then just ignore it.
Black 1984 R65 - the Wombat
Offline Tiedie
Re: Rubber bushing
« Reply #2 on: May 06, 2026, 04:17:38 AM »
You hit the nail on the head with where the crash bar meets with the motor next to the oil filter cover. And yes it has deteriorated as it is 42 years old. Yes the picture is crap it's the only on I could get to stick.
I keep getting message file is too big. :thud:
Thanks for the response, could you tell me what the part number is or where to find it.
Maxx BMW doesn't show it in the micro fich.
Offline Burt
Re: Rubber bushing
« Reply #3 on: May 06, 2026, 06:18:25 AM »
Fair enough regarding the photo.
From what I can remember they were a hand made item to replace the washer.  I think I have a diagram from an old Club magazine, that I will try and find in the shed.  I am off to a Club meeting tomorrow and will ask around, as they were never an official part, so the origin of the modification eludes me.  The bloke who had the kits fitted them in his workshop but is now retired.  It made a noticeable difference in reducing the vibration of the engine at that certain rev range.
The main problem is finding the correct grade and thickness of rubber, as there would have been a transfer of heat to the rubber.  If I remember correctly the torque on the engine mounting bolt remained the same.  Hopefully it should all be explained on the diagram.
Offline Tiedie
Re: Rubber bushing
« Reply #4 on: May 06, 2026, 06:49:06 AM »
Cool!!! :tekst-toppie:
Offline Burt
Re: Rubber bushing
« Reply #5 on: May 07, 2026, 08:09:05 AM »
I had a chat to the right person tonight and the rubber insert that was used here (in Oz) is a part from a tractor (high density rubber) but he was trying to remember which brand it was.  Depending on the size, sometimes a thin washer is used against the engine block as well.  The torque on the front "bolt" is just starting to squeeze the rubber.  Loctite can be used on the nut whilst the rear bolt torque is still the same.
The other option was by Luftmeister which is probably what you have in the US.  It was a cup with a rubber insert and then a washer which squeezed inside the cup onto the insert.
I am still looking for the diagram which will be around somewhere.  I know which folder it is in, I just need to find the folder!
I hope this helps.
Offline Tiedie
Re: Rubber bushing
« Reply #6 on: May 07, 2026, 11:57:44 AM »
Way cool, I have a 79' Kubota B7100D 4wd tractor. So I might be able to get the right washer. If you don't mind keep me posted.
Thank you for your help and time.
Offline Kelvin
  • R65LS
Re: Rubber bushing
« Reply #7 on: May 07, 2026, 06:33:09 PM »
I've always just put up with the vibration, so if it was me I'd replace the non-standard rubber washer with a standard metal washer.
From back in the day one of the vibration solutions was to use shoe rubber or polyurethane.
The vibration disappeared from my 83 R65LS when I installed the Siebenrock 860 kit. In a FB thread (mainly Tony Smith's input) we came to the hypothesis that BMW were using matching pistons for the short stroke R65 engines with the same tolerances they used for the long stroke 247 engines. This gave the vibration. So, you might fix the vibration by installing an 860 kit or by balancing the pistons you have.
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
Offline Tiedie
Re: Rubber bushing
« Reply #8 on: May 07, 2026, 07:33:09 PM »
That's nice to know since I've just installed the Siebenrock 860 kit in my  84' R65LS. And the guy that installed it noticed the rubber bushings were deteriorated.
Offline Tiedie
Re: Rubber bushing
« Reply #9 on: June 14, 2026, 06:25:25 PM »
Welp I stopped looking for those rubber bushings, my vintage guy went to work and asked the lead BMW tech and he had some spacers that fit perfectly and donated them to the cause. It seems to have less vibration since these were put in and the 860 kit. Ordered some Rhinomoto bar end mirror mounts for my CRG mirrors so we'll see how that helps my hand buzzing.
Ride safe.
