Author Topic: Circuit Breakers Instead Of Fuses  (Read 2176 times)
« on: February 14, 2007, 06:01:30 PM »
Saw a post on Boxerworks about an owner of a Harley that installed circuit breakers in place of fuses. An interesting idea. I searched for automotive circuit breakers, and found one that will fit into the blade type fuses used on newer cars and BMW bikes. Looks like another project in the making. Might come in handy on some dark ride when things go bad!
airhead
Re: Circuit Breakers Instead Of Fuses
« Reply #1 on: February 14, 2007, 08:37:39 PM »
Not to be a harbinger of all things negative............well, probably am come to think of it!! LOL Did you read my sarcastic comment about HD's and breakers?? The likelyhood of blowing a fuse at any time is rare, 'cept maybe after you have just worked on the bike, so a cct breaker is really of dubious benefit. Plus whatever tripped the breaker will still have to be found before it is reset, so no no real benefit over a fuse.
Breakers do offer the possible advantage of lower volt drop (which in reality is very minor) on lower volt applications if the contacts are in excellent condition, compared to the restriction of the fuse wire, though this would be lost over time/trips. Simple fuse maintenance/replacement every now and then will all but remove problems with fuses.
There is also the higher rupturing capacity of fuses over breakers. In effect, fuses offer better protection of the circuit under high amp faults, as they interrupt the circuit faster than a breaker can, plus open it completely. Breakers can, and have, welded together the contacts in those situations, and can't open the contacts faster than a fuse can blow.
Not to say I don't like breakers, but not in low volt situations like a vehicle. Save your money and either upgrade to blade fuses, or get a packet of spare fuses to suit.
BTW, breakers still need maintenance to make sure the mechanism's don't seize, which they can, and you had better hope they still trip at the rated current.........something you can be sure of with a fuse.
Bill...................;-)
« Reply #2 on: February 14, 2007, 10:23:20 PM »
I suppose a lot of your breaker objections could be solved by using aircraft breakers, but for the price you could probably buy a case of fuses...  Come to think of it, I have some of these in a box some where and have been wondering what to stuff in the small holes (currently plugged) that are in the RT dash...
« Reply #3 on: February 14, 2007, 10:36:07 PM »
Circuit breaker FAQ.
DC circuit breakers work on heat and need to cool before resetting.  Aviation Standard is 2 minutes from the time when you notice that they have poped before resetting.
About once a year, you need to manually pop a DC breaker to make sure corrosion has not set up inside rendering the breaker useless.
AC circuit breakes are Magnetic and can be reset almost immediatly.  I'm not sure about popping them once a year like the DC breakers though.
I am happy with fuses I can buy at any quickey mart.  One of my 8 amp euro fuses is now a 2-5 amp fuse mini blade type set up.  The mini's fit into tight spaces!
« Last Edit: February 14, 2007, 10:36:58 PM by Semper_Gumby »
