Author Topic: Valve Stem Location-‘83 R65 Snow Flake Front Wheel  (Read 5088 times)
Offline Charlie
« on: November 11, 2025, 09:16:07 AM »
The Valve Stem location is a perfect example of BMW not admitting failure.
I’ve owned BMW’s continuously since 1972. Rode Twins for 20 yrs and Triples for 30+ plus yrs. Always wanted a Twin again before I had to quit riding. Bought a R65 for low seat height and a little less weight I’m ‘Tickled Pink’ about a twin again.
So……..
Has anybody drilled another Valve Stem hole in a/the proper location ?   🤔
Charlie
Re: Valve Stem Location-‘83 R65 Snow Flake Front Wheel
« Reply #1 on: November 11, 2025, 11:23:47 AM »
Hello,
I bet drilling another hole is not as wise as it seems resistance wise of the wheel. Maybe the placement of the hole near the reinforced rim is not that dumb...
I have a nice angled adapter in my tray box in order to inflate the wheels without cursing too much.
« Reply #2 on: November 11, 2025, 11:57:24 AM »
In 18 years this s first time I've ever heard that suggested on any airhead forum. The only thing that has been done is to enlarge the hole to accept a tubeless valve.
I have no problem with the valve location when using a foot pump at home.  I carry a 90 deg adapter in case of needing to inflate away from home but it's never been needed. What I definitely would not do is leave the 90 deg adapter permanently attached as it would stress the valve stem and unbalance the wheel.
« Reply #3 on: November 12, 2025, 01:05:57 AM »
Barry,
In the United Kingdom, the most prevalent pump adapters on service stations is strait and had to be pressed on to apply the air.
Elsewhere, they use a Shrader type with a clip and this one is more difficult to affix on the stem. Hence the 90° adapter.
