Author Topic: Motor distance pieces  (Read 9968 times)
Offline skyblu79
« on: April 01, 2024, 06:45:18 AM »
There are 4 motor spacers, 3 of 6mm and 1 of 9mm.
I received the bike only with 3 of 6mm spacers. The 9 mm one was missing.
Where is the 9mm one installed?
Front left?
R65 1979
R65 '79
Offline dogshome
Re: Motor distance pieces
« Reply #1 on: April 02, 2024, 03:52:17 AM »
I can measure my 81 tonight, unless  you already solved it. Have you got centre stand with springs and swinging hooks? There are odd frame differences between years.
Offline skyblu79
« Reply #2 on: April 02, 2024, 01:28:18 PM »
No I haven't solved it. I tried measuring the gaps and the result appears to be 9mm front left. But I would like to be sure.
It would be nice to know why BMW decided this way.
Like I said I'm missing a spacer. I tried to order them in the online store and discovered that there are 3 of 6mm and 1 of 9mm. In the meantime I had already removed all the spacers and I didn't think to mark them.
R65 '79
« Reply #3 on: April 03, 2024, 12:45:58 AM »
Hello,
May I chime in ?
You could go to RealOem and, with your VIN, check the P/N of the 4 pieces.
If one is different, you should see where it goes ?
It has been a long time since I removed the engine on my `82 R65, but I do not remember that spacers where different.
Offline skyblu79
« Reply #4 on: April 03, 2024, 03:18:51 AM »
Hello,
May I chime in ?
Hi, already done. I looked on RealOem, but doesn't specify the differences.
I'm waiting for an explanation from someone who has already changed them
Stores also sell them without indication
https://www.bayermotor.de/en/distance-piece-6mm-9mm-motor-frame-bmw-r2v-boxer-modelle?language=en#googtrans(off)
« Last Edit: April 03, 2024, 03:26:28 AM by skyblu79 »
R65 '79
Offline dogshome
« Reply #5 on: April 04, 2024, 05:39:21 AM »
I need to clean my bike... I can't get access underneath properly at the moment either. The bike who must not be named on this website (Y@amaha Cru1ser) is having some electrical fettling behind her  :D
The rear two appear skinnier than the front two, front left possibly wider than front right. I have an RT fairing and conventional pipes, and don't think I can get a measurement properly.
« Last Edit: April 04, 2024, 05:50:11 AM by dogshome »
Offline dogshome
« Reply #6 on: April 04, 2024, 05:53:02 AM »
The engine is a snug fit in the frame. If you've measured and the front left needs the wider spacer, I doubt you'd get those very long bolts in if it was in the wrong place. I think the sidestand design made the spacer different.
Better pic of front left attached.
« Last Edit: April 04, 2024, 05:57:04 AM by dogshome »
Offline skyblu79
« Reply #7 on: April 04, 2024, 02:10:05 PM »
I also think that the side stand could influence the choice of the wider spacer, what else?
I'm curious and was waiting for some "experts" to confirm
R65 '79
Offline dogshome
« Reply #8 on: April 05, 2024, 05:21:58 AM »
You've only got me  ;D
Offline skyblu79
« Reply #9 on: April 06, 2024, 03:06:12 AM »
if that's the case I'll have to appoint you as an "expert"  :beerchug:
R65 '79
