Author Topic: Aftermarket Brake Pads For ATE Calipers  (Read 1661 times)
« on: December 06, 2023, 01:00:16 PM »
Going to replace the master cylinder seal on my silver ‘82 LS .
The current pads look like OEM .
I’ve got EBC pads on my ‘81 R65 and greatly improved wet braking over the OEM pads, no noticeable improvement in dry conditions .
When I replaced the pads on my ‘81 R65, I ordered FA18 EBC pads, according to the EBC catalog this pad was good on all R65’s from’81 onwards, they are good for Brembo calipers .
 I used a die grinder and a rotary bit to alter the pads to the ATE calipers .
My silver LS has ATE calipers .
Just wondering if there are better pads out there, any personal experiences ?
If anyone is considering EBC pads, FA57 work on ATE calipers .
« Last Edit: December 06, 2023, 01:06:10 PM by Bob_Roller »
Re: Aftermarket Brake Pads For ATE Calipers
« Reply #1 on: December 09, 2023, 05:01:01 AM »
I've only ever used the EBC FA57 pads so have no other comparison.  Any inadequacy in the braking I put down to what is by modern standards a very poor hydraulic ratio.  They improved it in 81 by going from a 13mm to 12mm master cylinder on a single disc. I should have done something about it but after 17 years I wonder if I'll ever get around to it.
« Reply #2 on: December 09, 2023, 03:35:17 PM »
The only thing I would like to improve on the R65, is brakes . After putting EBC HH pads on my oil head  I realize how, under powered the brakes are on the R65 .
