Author Topic: Links Und Rechts Rocker covers  (Read 1539 times)
Offline rickloader
« on: August 07, 2022, 10:45:35 AM »
It has been a puzzle that my 1980 rocker cover has an R cast into the left one. And the other side (R) is lettered "L". A valve clearance check being over due, I find  the interior of the cover marked Links on the one with L on the outside . And the other says Rechts.
I guess that even with the bike having documented proof of professional sevicing, the dealers seem to have swapped the covers. I have put them  on the "correct" sides. No oil leak or mechanical disaster yet.
So if the covers can be transposed Why did BMW specify right and left?
I mean left as you sit on the bike ie port side. nearside uk. Surely BMW can`t mean left and right as you stand in front looking backwards?
Rick
1980 R65 (January 81 registered)
1977 Norton Commando
1976 Moto Morini Strada
1960 Velocette Mss
Offline wilcom
Re: Links Und Rechts Rocker covers
« Reply #1 on: August 07, 2022, 11:06:10 AM »
  (  I believe, I've been told, I think,)
The fins are parallel to the ground when on correctly. Transposed, it makes the fins droop to the rear.
« Last Edit: August 07, 2022, 11:15:56 AM by wilcom »
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: August 07, 2022, 11:09:54 AM »
Exact.
And the R or L markings are only on one face which should be put underside for not be shown when in concour ....
Offline rickloader
« Reply #3 on: August 07, 2022, 12:06:26 PM »
Thanks for your help. So i need to turn the covers 180 degress so that the R, L are underneath .
Thinking some more : left - right transposed but numbers uppermost will be the same as the correct left - right , letters down. So i am now wrong  ( letters up) and the dealer was right! ( but wrong)
I can not see any droop of the cover lines. They appear symmetrical
The Haynes manual says that at high revs the rockers will hit the cover. Surely this can only be when valve float is occuring, and you are in trouble anyway?
1960 Velocette Mss
« Reply #4 on: August 07, 2022, 04:23:26 PM »
It doesn't matter a damn.
Some people count washers too.
I just ride and enjoy my bikes
Offline wilcom
« Reply #5 on: August 07, 2022, 05:41:24 PM »
Droopy fins............ :naughty:
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #6 on: August 08, 2022, 10:45:48 PM »
Yeah, they work either way but upside-down they look kinda dorky...  :puke2:
Offline dogshome
« Reply #7 on: August 09, 2022, 02:11:15 PM »
It comes with mileage too. Bike or owner  :ROTFLMAO:
« Reply #8 on: August 12, 2022, 11:10:45 PM »
Oooh, I not touching that one!
