Author Topic: Oilhead ignition coil  (Read 3872 times)
« on: June 11, 2022, 04:47:30 PM »
My oilhead quit on me Thursday on the way home 2 miles from work and 110 F, 43 C .
A disastrous story of getting roadside  emergency towing, only took them 8 hours to get to me !!!
I did a little bit of troubleshooting today after work .
I pulled a sparkplug lead off and put a spare plug on it .
Got a fat reddish orange spark, so I'm thinking the coil is bad .
Can't find my oilhead manual cd, so anyone have access to one if so what are the resistance values for the primary and secondary circuitsof the coil .
I had it loaded on my previous computer, but neglected to load it on this one .
Found the cd, only info in the manual, connect coil to BMW test equipment !!!!
No values are there .
« Last Edit: June 11, 2022, 04:53:54 PM by Bob_Roller »
Re: Oilhead ignition coil
« Reply #1 on: June 12, 2022, 09:32:43 PM »
Dang.  Can you determine what kind of ignition amplifier is used?  If you can you might be able to do some research and find some nominal values.
« Reply #2 on: June 12, 2022, 11:48:20 PM »
I found some technical info on the Euro Motoelectric site.
A replacement coil for this bike has .6 ohm primary and 7.2k ohms for the secondary .
« Reply #3 on: June 14, 2022, 09:16:28 PM »
Got the coil removed, had to wait until I could drain the fuel out of the oilhead and put it other vehicles.
The primary checked good at .6 ohms, the secondary was open .
I've got a replacement coil and ignition leads on order from Euromoto Electric, along with some odds and ends I can use .
From the wiring diagram I have the engine management module controls the ignition, no other amplifiers are used .
« Reply #4 on: June 14, 2022, 09:35:49 PM »
Glad you got it figured out.
« Reply #5 on: July 04, 2022, 03:04:27 PM »
Coil and wires solved the issue .
« Reply #6 on: July 05, 2022, 09:05:58 PM »
 :thumbsup:
