Author Topic: Front Disk  (Read 1751 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Front Disk
« on: May 30, 2022, 03:39:49 AM »
Hello again brains trust - how is everyone  ;)
I am about to fit a second disk to the front. I have bought all new brakes lines top and bottom - (steel braided of course) - and splitter. A 2nd hand calliper which i have fully refurbished. I already have a 15mm master cylinder fitted.
So my question is - how to bleed the new system. I'm guessing as it's 2 completely isolated lines I should bleed one calliper at a time. But being unsure I need some advice.
Thanks in Advance  8)
1984 R65 (860)
Offline dogshome
Re: Front Disk
« Reply #1 on: May 30, 2022, 06:55:25 AM »
Hiya, It's actually very simple as all the bubbles tend to go up to the master cylinder and out through the little bleed hole. You will also find that simply opening the taps at each caliper fills 90% of the system.
Then squeezing the lever in out with the taps closed gets most of the air out out and then finish off with the squeeze and close a couple of times each side.
If you let it sit, it almost does it itself apart from the very last bit in the very end of each caliper where the bleed tap is.
Re: Front Disk
« Reply #2 on: May 30, 2022, 11:27:32 AM »
Hello,
In this situation, I fill the system from below. I use a Mity Vac pump to press the fluid from one bleeding screw and when liquid shows in the master cylinder reservoir, I close the bleeding screw and change caliper.
If you are lucky, the system is filled and bleed in one go...
Offline Adrian
Re: Front Disk
« Reply #3 on: June 01, 2022, 02:49:34 AM »
Thanks guys - I'll see how I go  :dankk2:
1984 R65 (860)
Re: Front Disk
« Reply #4 on: June 01, 2022, 10:39:50 AM »
The one time I had my system drained I also filled from below using a large syringe. Worked a treat with very little if any further bleeding necessary.
Offline dogshome
Re: Front Disk
« Reply #5 on: June 01, 2022, 10:53:12 AM »
I think that is called an "Enema"  :)
Re: Front Disk
« Reply #6 on: June 01, 2022, 01:52:45 PM »
Thankfully I've never had one of those but I do see how it reads   :)
Re: Front Disk
« Reply #7 on: June 05, 2022, 09:15:06 PM »
I bleed the usual way with a hose off the bleeder down in tome fluid.  When I get it to the point where I have a fair "pedal" I clamp down on the lever as hard as I can and secure it with a tie-wrap overnight.  The next day clip off the tie-wrap and the lever will have zero sponginess!
