Author Topic: Fuel Filter  (Read 5131 times)
Offline Kelvin
  • R65LS
Fuel Filter
« on: March 16, 2022, 12:46:30 AM »
I've had red sludge from the tank liner in the LHS carburettor float bowl despite having a fuel filter installed. The filter I'm using is Mahle KL13, available at both Motobins (UK) and Munich (Oz). Is there a better filter available?
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
Re: Fuel Filter
« Reply #1 on: March 16, 2022, 10:14:58 AM »
Tank liner should not get past that filter .
I'd suggest making sure that the fuel lines down stream from the filter are clear of liner bits  .
Re: Fuel Filter
« Reply #2 on: March 16, 2022, 05:06:29 PM »
The real problem is renewing the liner before you have rust holes.
Acetone will remove the old liner.
I have over the years used a number of tank lining products. Most have various problems, KREEM and POR hold a special place in my heart for being worthless junk
The two I use and reccomend are::
Red, White and Blue - an Australian product www.redwhiteandblue.com.au   One of the few manufacturers confident enough to put how-to videos on YouTube. It works brilliantly - full stop.
The other is RedKote, very similar to the OEM liner the requires a lot more prep than RWaB, but it does work well.
