Author Topic: Bend jugs stud  (Read 919 times)
Bend jugs stud
« on: March 06, 2022, 05:07:04 AM »
Hello Guys,
I'm in the process of renewing my 1982 R65 engine. And while moving it, I made a mistake and bent one stud holding the jugs.
So I need to replace it.
Question : What is the best way to remove the bent one ? What is the best way to install a new one ? What Loctite should I use ? If any ?
I'm stuck...
Many thanks in advance for your help and answer.
Re: Bend jugs stud
« Reply #1 on: March 06, 2022, 03:11:38 PM »
Double or triple nut the upper threads and then turn the lowest nut .
Also there a threaded stud removal tools .
https://www.xtremediesel.com/lisle-71200-stud-removal-tool?msclkid=5608dafc638f1fd4c907b8d940d983b7
Re: Bend jugs stud
« Reply #2 on: March 06, 2022, 06:35:57 PM »
What Bob said.
Re: Bend jugs stud
« Reply #3 on: March 07, 2022, 12:53:37 AM »
Thank you both for your answer.
OK. So no heath needed, nor special treatment ?
I would have thought I needed some magic voodoo to have them out !
A new one has already been ordered.
Thank you.
