Author Topic: only firering on one  (Read 4520 times)
trolle
Re: only firering on one
« Reply #15 on: December 04, 2008, 04:28:52 AM »
Look at the fuel lines at both sides, are they frayed at the ends? if so, one of the carbs is getting a wrong mixture making igniting the mixture difficult.
greetings from a clear, calm and freezing north
« Reply #16 on: December 06, 2008, 11:25:25 AM »
When stripping again i find that the choke fuel feed molded in the float bowl is blocked theres a small hole at the bottom which ive poked and prodded but it wont clear would it be a problem if i drilled a small hole slightly higher to restore the feed???
ps
frost is my freind more burst pipes please i need the money for my bike
« Last Edit: December 06, 2008, 11:27:59 AM by Lucky_Lou »
tagordon
« Reply #17 on: December 06, 2008, 01:20:11 PM »
"Sir, please move away from the drill."
Please remind me which carbs you have.
Look carefully down inside the bowl.
There is a jet inside the tube on some.
If the jet is there you can remove it with a small flat bladed screwdriver.
Then soak it in carb cleaner until you can poke a small wire through it.
Removing old stuck in jets can be very difficult sometimes.
So I would try soaking the entire bowl in carb cleaner overnight to soften up the crud.
Put any ideas of modifiying the carbs out of mind.
Stick with us here and collectively we will resolve the problem, eventually.
« Reply #18 on: December 07, 2008, 08:14:18 AM »
Ok drills back in its box....its a Bing constant depression type(R65 1980) theres fuel flowing from the main bowl chamber into the choke feed chamber on the cylinder thats running but the hole seems to be blocked on the one thats not?? Ill call and get some carb cleaner on monday and soak it overnight ive been using aerosols so far .The feed tube looks to small to have a jet in it but ill check on monday(the bike is in my workshop not at home)
« Last Edit: December 07, 2008, 08:16:51 AM by Lucky_Lou »
« Reply #19 on: December 07, 2008, 09:22:32 AM »
<snip>
Ok drills back in its box....,snip>
Phew!  That was close! :o
tagordon
« Reply #20 on: December 07, 2008, 01:07:33 PM »
Is the arrow pointing to where you beleive you have the blockage?
This tube only feeds the enrichener/auxillary carb.
Would not cause a problem past 1/4 open throttle.
It picks up fuel from the bottom of the bowl through a hole that feeds the jet I mentioned.
See next post for more info.
tagordon
« Reply #21 on: December 07, 2008, 01:11:34 PM »
The arrow in this pic shows the passage in the bowl where the jet is located.
This not a circuit that would cause a problem when off idle and more than 1/4 open throttle.
tagordon
« Reply #22 on: December 07, 2008, 01:45:07 PM »
It is possible that all I am about to say has already been covered previously.
I am recapping to get it in one place for myself, to ascertain where we are in the process.
Your statement that covering the air inlet allowed the engine to run on both sides;  means you are lean on that side.
Check if you have not already for fuel delivery from the tank. Is the crossover parially plugged going to that side?
Drop the bowl and check the flow and float level.
If you know the carb is receiving fuel from the tank and the bowl is filling properly.
Then have you checked to ensure that the piston in the carb is returning all the way down?
Take the pipe off the carb that goes to the airbox.
Watch the piston go up and down while you blip the throttle to say 4000 rpm.
Is it returning all the way down when the rpms return to idle?
Eyeball both sides to see if they are behaving the same.
If you checked the diaphragms did you make sure to reinstall with the little tabs located correctly.
Having it improperly oriented could cause the piston to stick in the up position.
Also the spring may be buggered up in there causing the piston to stick open/up.
If the piston on the side with the problem is not acting the same as the side without the problem we are narrowing down the cause(s) of the problem.
Most important to me when diagnosing a problem is to start at one end of the system and check/troubleshoot untill I find a point where things are not as they should be. Then figure out why its not as it should be.
The problem must be identified, then the cause of the problem identified, only then can the proper repair be identified.
"Really quite simple Watson;" "not."
At work we refer to this as:
1. Complaint
2. Cause
3. Remedy
HTH
Troy
« Last Edit: December 07, 2008, 01:53:31 PM by tagordon »
« Reply #23 on: December 07, 2008, 03:40:03 PM »
Item 17
Thats where there is no feed.......illclean it somemore to see if there is a jet in the bottom
will try to do this tomorrow and let you know what i find
« Reply #24 on: December 10, 2008, 01:26:28 PM »
Ok now im realy tearing my hair out....... the feed to the choke is now clear, couldnt get the jet out but managed to clear it with some fine wire and snipe nose pliers still got the same promlem slightly improved by opening the air scew will only run if i give it slight revs and not on idle tweaking the choke back a bit at a time, i feel nearer to sorting it than i was but still frustated to the point of maybe getting my wallet out and letting a pro have a play.
tagordon
« Reply #25 on: December 10, 2008, 01:58:02 PM »
There is an air port/hole on the upper out side of the carb that is sometimes plugged with crap.
It goes unnoticed untill it becomes a problem. It is hard to see unless you look for it carefully.
Sorry no pic available at this time.
Did you soak the carb and blow everything out?
You may have missed this port. I know I missed it twice.
Troy
« Reply #26 on: December 10, 2008, 02:21:56 PM »
Ive my airline on every hole i can find all seem clear but will strip everything one more time to double check ....out of intrest any idea where the air screw should be set or is it trial and error and what is item 19 in the last diagram  looks like some kind of cap but havent got one on mine???
Offline donbmw
« Reply #27 on: December 10, 2008, 02:41:08 PM »
About 1/2 to 3/4 of a turn is where I set mine the first time.
Don
fastcataz
« Reply #28 on: December 10, 2008, 05:34:46 PM »
Have you checked your carb to manifold rubber for cracks?  Even a small one can cause some weird running at low RPM's.
« Reply #29 on: December 11, 2008, 08:26:43 AM »
As don mentioned, screw the air adjustment screw all the way in and then back it out about 3/4 of a turn for starters - you'll possibly have to fiddle with it a bit later but this should at least get you into an operating condition if all else is right.
Are the levers for the carb (main throttle and enricher/choke) both working smoothly and moving through their full range (not getting stuck/stopped, or have more than
1-2 mm of slack ) ??  I am thinking that even if the jet in the enricher circuit isn't blocked, if the lever /cable slack isn't set right you'll still have issues starting that side.
